A Prius ECT Spoofer MCU Controlled
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ccdisce, Jan 11, 2011.
  1. ccdisce
    ccdisce Active Member
    259
    142
    Stone Mtn GA USA
    A limited number of PWBs came in and I built 3 just to see how they assembled and flashed them. Tested them in the car and they work fine.
    A pic is attached.
    3 people like this.
  2. TheForce
    TheForce Ron Paul 2012
    3,454
    462
    Wheelersburg, Ohio
    Have you set a price yet?
    I'm having trouble moving my Arduino version over to a project box. Since I'm finding less and less time to work on mine I may just buy yours so I can get get my mess out of the passenger side foot well.
  3. mrbigh
    3,686
    684
    Long Island, NY
    Picture to small
  4. TheForce
    3,454
    462
    Wheelersburg, Ohio
  5. stealth_mode
    stealth_mode New Member
    Switzerland
    Great work!
    Are you selling yet? Put me On the List any way!
    T
  6. ccdisce
    259
    142
    Stone Mtn GA USA
    The price is still $30 + Shipping & Handling which I estimate as an additional $3 within the US.
    I am thinking of adding a short cable with Tyco MTA connectors to make it plugable.
    The SD cases are not here.
    The Hysol PCB air-cure PCB overcoat is not here, or Parlene could be used to protect against moisture especially when used on a Gen III in the engine compartment under the covers and next to the ECU.
  7. ccdisce
    259
    142
    Stone Mtn GA USA
    Soon.
    I should be recieving the remaing parts required shortly.
  8. ccdisce
    259
    142
    Stone Mtn GA USA
    I will take a macro pic this weekend and post it.
    An even smaller version was laid out using a pic16f684 in a QFN16 package and a mcp4911 in a DFN8 package.
    The SW has already been ported over to the DIP prototype and tested. Licensed Eagle Lite was used as the layout tool.
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,702
    479
    63
    Sold! Thanks! Could you remind me if the temperature set points are adjustable? :)
  10. TheForce
    3,454
    462
    Wheelersburg, Ohio
    I'll buy one now from you if you'll let me. I dont need a case or anything. I have small cases I could put it in and wrap it up.
    I would also like to know the set points.
    Does your verision stop faking at say 100F and start faking at 105 or something like that so there is a buffer range or does it have a start/stop faking at a set number like 100F?
  11. bartonramos
    bartonramos Junior Member
    Brookline, MA
    I'd like to buy one asap. What do I have to do. (Thanks so much for sharing this with us all!)
  12. ccdisce
    259
    142
    Stone Mtn GA USA
  13. mrbigh
    3,686
    684
    Long Island, NY
  14. ccdisce
    259
    142
    Stone Mtn GA USA
    In this version, the ECTSpoofer does not have the required push buttons and 3 digit LCD Glass to enable user adjustments to the trip points.
    The trip points are set at build time,
    2 EQU HEX values are changed prior to BUILD ALL.
  15. ccdisce
    259
    142
    Stone Mtn GA USA
    If you do not object PM me with email addy and shipping address, I will log into my PayPal act and see if I can remember how to generate an invoice.
    Yes there is an Hysteresis of around 8 Fareneheit degrees.
    Warming UP: ECT starting say below 90 deg F spoofing starts at around 114 deg F.
    Temperature as read by the ECU (and a Scangauge) then goes to 168 +4-2 deg F.
    Spoofing stops at 172 deg F with the Spoofer disconnecting itself so that the ECU can bring the fan on if required as the temperature rises.
    Cooling Down: Spoofing will start at 170 deg F, Scangauge will show 166-170. At 108-107 deg F actual, the ECU (and Scangauge) will change from 170 to 108.
    2 people like this.
  16. ccdisce
    259
    142
    Stone Mtn GA USA
    I have yet to recieve the SD cases I ordered, I will let you know when i can ship.
  17. 2009Prius
    2,702
    479
    63
    So at temperatures lower than 108F it also disconnects itself to let the ECU measure the real temperature?
  18. ccdisce
    259
    142
    Stone Mtn GA USA
    Yes, and please be careful working in the engine compartment at that time as if the status is READY the engine could start...heater on?
  19. JBumps
    JBumps Member
    167
    Morgantown, WV
    2013 Prius Plug-in
    This is the type of plug and play, high quality product I've been waiting for since February of 2008. I read and attempted a copy of several PC'ers bread board hacks, with limited success. Please, please, please tell me that you are going to have a consumer ready version in the near future.
    Any idea how much of the work you've done here would be easily transferrable to a Ford Escape Hyrid version of your project?
    Will anxiously follow the thread to see how you do and hope you can get enough into production to recoup the value of at least some of your time and investment!
  20. ccdisce
    259
    142
    Stone Mtn GA USA
    Thanks for your encouragement.
    I am not sure when this 'device' can be tested on a Ford Escape Hybrid as I do not know the response of the NTC circuit that is probably used .
    With this in mind I know that the NTC circuit values used in the EEC-V in my 02 Stang GT and I have built a load using the temperature trip points similar to the Prius and it works fine, no hardware changes required. For anyone interested the ECT uses pin 38 on the EEC-V's 104 pin connector.
    For use on a Escape Hybrid or any other vehicle that uses the Linearized NTC approach to determine ECT, the ECTSpoofer will need 3 values to be loaded at build time. Hooks are in the Firmware to make the unit determine the 3rd parameter itself but has not been enabled.
    If you know what pin is used for the NTC sensor, +5V and GND, Vout at say 115 deg and 170 deg a build for the Ford Hybrids could be generated.
    2 people like this.
Loading...
