A Prius that drives 100 km / 60 miles in EV (Belgium, Europe).
Discussion in 'Gen 2 Prius Main Forum' started by WaWa, Aug 27, 2014.
  1. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    No bell is ringing. The ICE is regularly forced to turn, together with the electro. Of course there is no petrol used = like driving downhill. This is nesesary also to make the alternator run that regenerate the 12 V battery.
    Rgds | Walter
    #21 WaWa, Aug 30, 2014
  2. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    No bell is ringing. The ICE is regularly forced to turn, together with the electro. Of course there is no petrol used = like driving downhill. This is nesessary also to make the 'alternator' run that regenerates the 12 V battery.
    Rgds | Walter
    #22 WaWa, Aug 30, 2014
  3. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    There is an oil pump in the transmission that is engine driven. It has never been clear on the gen2 how critical this lubrication is as when in EV mode "standard fitting on all UK/EU Prius" this pump does not run. Since from what I have seen of the transmission all the bearings are roller or ball types surrounded or bathed in oil the pumps use is vague. It is however driven when the engine is spun by MG1.
    Walter your use of the term alternator "although strictly correct" is a little confusing as the Prius does not have a separate alternator and MG1 performs this operation but does not charge the 12 volt battery directly. The 12 volt is charged by a DC/DC converter off the HV battery.
    John (Britprius)
    #23 Britprius, Aug 31, 2014
    Data Daedalus and planetaire like this.
  4. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    Hello ‘Electrified-hybrid friends,
    Well, I am not sure to have the right answer for you. Therefore I will transfer your request to my partner in crime with whom I made my system.
    Personally, I believe that this lubrication happens when the ICE is running once-in-a-while when in EV.
    Anyway, I am using it since 9 months and 9000 km / 6000 miles and nothing exploded (yet)!
    When driving in mixed mode, it is business as usual.
    Until I have a better answer – have a nice Sunday,
    Walter
    #24 WaWa, Aug 31, 2014
  5. bisco
    51,829
    at least we know where i live.:) and bisco already has a pip.;)
  6. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    ...I do not follow... Sorry... Can you elaborate?
  7. bisco
    51,829
    sorry, that was for poster #18.:p
  8. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    I have no lubrication problems of that kind. In fact, no problem at all with anything.
  9. bisco
    51,829
    thank you, that's good news for those doing a conversion.
  10. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    Now I go for less than 1.1 L /100 = 400 mpg (?)
    m.wynn likes this.
  11. tvpierce
    tvpierce Senior Member
    951
    882
    Maine
    2013 Prius v wagon
    Thanks for sharing your project with us -- very cool. And excellent results with economy!
    One question: Why did you choose the 18650 batteries (AA in the USA)? Couldn't you have reduced the number of batteries by using D cells?
  12. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    Well, it is being said that small cylindrical cells are having a better power-to-weight ratio. It is remarkable to reach 16.5 kWh on 85 kg = ± 160 pounds. Isn't it? Moreover it all fits nicely under the floor of the thrunk.
  13. bisco
    51,829
    i wonder how they compare overall to the cells toyota uses in the pip, which take up half the car for 4.4 kWh.
  14. tvpierce
    951
    882
    Maine
    2013 Prius v wagon
    I didn't know that... but I'm very new to all this. I love learning new stuff. Thanks!
  15. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    @bisco: I do not know the PIP too well. As it seems, we have Lithium cells in the PIP's sold in Europe, while in the US it is NicCad. In any case, it is understandable that Toyota must be conservative and cannot take the risc of adventuring a brand new type of cell. Imaging making a million cars with faulty cells.... My risk was personal. The car itself was only $ 9.000 worth and + $ 10.000 new parts gave me an EV (almost) for 19.000. If I would have failed dramaticcaly and the whole lot went into fire, I would have lost this $ 19.000, but the world would still continue to revolve 24 hrs/day. However, it did not happened, and I enjoy the car very much: it remains silent up to a speed of 118 km/h = almost 70 m/h; after that the ICE helps. But, my consumption remains very low.
  16. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    View attachment 82248 4000_km_Prius.JPG ► ► Today (check on my smartphone next to my car computer), I reached an absolute record: 1.3 L/100 km over 4.000 km (2.700 miles @ 300 mpg).
    No need to say that my converted Prius remains the cheapest car to drive.
    My next goal is 5.000 km @ 1L/100 km or less!
    Thanks to Nico from AEP- Eindhoven, NL, who made this possible for me!
    m.wynn likes this.
  17. bisco
    51,829
    showoff!:p
  18. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    Haha Bisco... But no Showoff in my wallet...
  19. planetaire
    planetaire Plug in 20 kWh 85 km/h or > 208km range
    190
    139
    France
    Nice odb.:)
    Ok for your wallet, but what about your calculator, walter ? :sick:
    1.3 L/100km could be converted to 180 mpg, isn't it ? (y)
  20. WaWa
    WaWa Junior Member
    29
    Brussels, Belgium
    Thank you, Planetaire,
    It's not my calculater that is to be blamed, but my brains.
    [hope to see you again, if my Prius goes to the right direction again)
    Walter
