A PSA for Gen 2 Prius Owners...
Discussion in 'Gen 2 Prius Main Forum' started by drewker, Dec 29, 2019.
  1. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    If by a "car battery" you mean a standard flooded Lead/Acid battery, then yes, it will work fine – in the short term. It is not as safe for use in the cabin, nor will it last as long. But horses for courses.
    GrayRaceCat likes this.
  2. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    The 12v
  3. dolj
    dolj Senior Member
    8,646
    4,397
    Yes, I got that, but was it flooded Pb/A or AGM?
  4. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
  5. dolj
    dolj Senior Member
    8,646
    4,397
    Cool. Specific details as to which make and model.
    nssdiver likes this.
  6. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I thought it AGM But it’s actually a Optima battery here’s the model number Part #: BAT N9951HEV from Napa I think the old battery was AGM
  7. drewker
    drewker New Member
    23
    Phoenix, AZ
    Battery now showing 12.6 volts in ready mode. Still having abs problems however. If anybody has any more ideas let me know. Im about to give up on this thing. Will be taking off the wheels to maybe clean the sensors. I read something about zero point calibration but have not tried it yet
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,088
    6,950
    Texas Hill Country
    Most likely you need to swap out the abs master cylinder and pump. As far as the 12v, once the car is in ready mode the inverter is supplying all the 12v requirements usually at 13.5v or higher. So the 12v is very unlikely to be the problem unless its so depleted it wont ready the car. Its possible the battery is severely discharged to the point the inverter/converter can not pull it up to 13.5 but thats a severe discharge. Any auto supply can load test your battery.
    #48 rjparker, Jan 19, 2020
  9. rjparker
    11,088
    6,950
    Texas Hill Country
    fotomoto and drewker like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I just came across this thread. 12.6V in ready mode looks like a problem to me. That's the voltage I would expect with the car off after resting overnight. Either something is drawing some serious current to pull it down or the DC/DC converter isn't up to snuff. In ready mode it should show about 13.8 to 14.1 or so.
  11. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    Geez! I got a Toyota true start last week for $260 with text and popped it in myself in like 15 minutes! What we're those idiots doing? Playing cards?
  12. drewker
    drewker New Member
    23
    Phoenix, AZ
    When i turn the car on it is 13.9...wow so maybe i should charge it up at autozone. Dash is going out again. This is the 2nd 12v battery in 2 months
  13. George W
    George W Senior Member
    939
    520
    San Antonio
    What is the 'Resting Voltage' of the 12V battery? In other words, what is the voltage measured at the battery before anything in the car is powered on? The battery needs to sit for several hours to read resting voltage.
    dolj, jerrymildred and nssdiver like this.
  14. jerrymildred
    11,517
    14,167
    Tampa, FL
    These two statements can't both be true.
    For the resting voltage, pop the hood before you shut off the car in the evening. Then, in the morning, before you open any doors on the car, check the voltage at the jump points under the hood. That's the resting voltage.
    dolj and nssdiver like this.
  15. drewker
    drewker New Member
    23
    Phoenix, AZ
    Ready mode meaning engine not on.
  16. George W
    939
    520
    San Antonio
    How many ways can you avoid answering the same question?
  17. nssdiver
    nssdiver Me digging' life
    Syracuse, NY
    Four Touring
    Immaterial. If the car is “booted up,” it is on HV power, whether from traction battery or during regeneration or charge mode.
    iPhone ?
    GrayRaceCat and dolj like this.
  18. drewker
    drewker New Member
    23
    Phoenix, AZ
    Gee george i do not know. Yeah im really avoiding questions here. Thats why i am writing all this crap. Totally useless comment
  19. jerrymildred
    11,517
    14,167
    Tampa, FL
    That's not what Ready mode means.
    As @nssdiver said, it makes absolutely no difference if the engine is running. If it's in ready mode, the DC/DC converter is charging the 12V battery from the traction battery. Ready mode just means the car is ready to drive. The engine may or may not be on. The 12V charging system doesn't care. So yeah, your information has not enlightened us.
    GrayRaceCat, Mendel Leisk and dolj like this.
  20. George W
    939
    520
    San Antonio
    Several members have tried to ask you, what is the voltage of the battery before you start your Prius? They're trying to determine the baseline number, to help you understand if your battery was truly charged completely.
    No matter how many ways they try to ask you, you seem to sidestep the question.
    The value you have posted does not indicate a fully charged (new) battery.
    If you have access to a cheap voltmeter, trying the following. Disconnect your 12 volt battery from the Prius. Don't remove it from the car, just let it sit overnight. Then first thing in the morning, measure the voltage before you reconnect it to the car. If you get anything less than 12.8 volts, then your new battery has not been fully charged.
    There could be a defect with your new battery, or the place you took it to never put it through a full charging cycle. No one can tell at this point because you mention values that are different, even within the same reply
