A rubbing noise only when gas engine is running
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Navitas, Feb 19, 2023.
  1. Navitas
    Navitas Junior Member
    Pennsylvania
    2012 Prius two. Recently my car has made a new noise after I brought back from the mechanic. This is a reason why I don't trust mechanics in general. Only when the gas engines running does it sound like either a squeal as if it was bearing or a rubbing noise coming from the engine as if I had playing card in bicycle spokes. I could be parked or rolling and it makes that noise if the gas engine is running. The noise emanates from the engine that is on the driver side. Any thoughts on what this could be?
  2. JC91006
    16,827
    8,600
    What service did you do at the mechanic?
    52,379
    How many miles on her?
    this is the gen 2 forum
  4. Navitas
    Pennsylvania
    A simple annual inspection. Nothing more. But since then I found out from the locals that this particular Monroe was very corrupt and will **** you every chance they can.
  5. Navitas
    Pennsylvania
    247k and mine is a Gen 2 as far as I know
  6. bisco
    52,379
    2004-2009 is gen 2, 2010-2015 is gen 3
