A way to force the...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by douglasjre, Jun 27, 2020.
  1. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    ...A/C to stay 100% recir?
  2. ChapmanF
    19,005
    It ordinarily stays recir if you put it there. The traction battery ECU does have a veto though (recirculating air does not cool the battery, only air that flows in the front and out the back, so if the battery ECU wants more cooling it will send a request for fresh to the A/C).
  3. PriusCamper
    PriusCamper Senior Member
    13,446
    5,428
    Pacific Northwest, USA
    A robotic hand that pushes the appropriate buttons for you?
    There's nothing in Toyota techstream software that allows you to change that... But maybe an A/C shop could find a way to disable it when it its in recirculation mode? But I'm skeptical the car's computers will be ok with that....
  4. ASRDogman
    ASRDogman Senior Member
    8,056
    4,084
    If you have the temp set low and fan is low, the evaporator will start to freeze.
    If you have the a/c set to auto, it will change to fresh air to keep the evaporator from freezing.
    If you choose manual a/c, it will stay in the fresh air position if you put it there.
    PriusCamper likes this.
