A way to turn reverse beeping off??
Discussion in 'Prius v Accessories and Modifications' started by pontiac5oh, Mar 20, 2013.
  1. pontiac5oh
    pontiac5oh New Member
    2013 Prius v wagon
    Its annoying as hell. I tried the method for the gen II Prius I found here in the forum but it didn't work. I looked through the audio display unit for a way but couldn't find it. In the owners manual there is a "beep once option" in custom settings but its says it can only be done at the Toyota dealer. Do they need a scan tool to program it or is there a sequence of buttons pressed to change the function?
    Tyler
  2. labell
    labell Junior Member
    38
    TN
    2013 Prius v wagon
    Welcome to another new 2013 v owner! Unfortunately that method does not work with our later model. It can only be changed at the dealership from continuous to one beep, or done by yourself if you buy a Scangauge or similar tool (don't ask me how because I am not savvy on that, but others here are.) I am going to ask at the dealership next time I am there. Some have done it for free and others have charged based on reports I have read on the forums.
  3. DerekNIU
    DerekNIU New Member
    Chicago Suburbs
    This thread has all the information you need. I was pretty nervous about trying it (I'm NOT a car guy and didn't want to break it), but the instructions guided me through it perfectly. I wish the dealership would have just done it for me for free, but they said "it wasn't possible to turn it off." Spent $17 on the scanner and $5 on the Android App. 100% worth it.
    Turning off the reverse beep on a 2012 Prius v | PriusChat
  4. Corpus Delicti
    Corpus Delicti Junior Member
    27
    Southwestern Louisiana, USA
    I can echo what DerekNIU said. I bought the BAFX brand device on Amazon ($23) and used a free Android app called ELM 327 Terminal. Following the instructions and codes in another thread elsewhere, it worked like a charm. Today I was able to change the backup beep to one, and also disabled the seat belt reminder. Both took me about 2 minutes total, if that. Many thanks to all who posted instructions and codes.
    squeege and Robroy like this.
  5. mikefocke
    3,692
    1,644
    Sanford, NC
    My dealer did the one beep back up setting when asked as part of a routine covered by initial warranty for oil changes service. I presume they read the codes at the service so already had their computer hooked up. It was free.
    I left the seat belt beeps on as, while I hate them, I need the reminder.
