A "What if.." question...
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, May 7, 2017.
  1. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Do you use a fuel stabilizer to reduce the chance of old fuel causing damage or gumming up the system?
    priuscatprimeguy likes this.
    52,750
    i never have, but i add fuel every 6 months, as the pip manual recommends. interesting that they've gone to 12 months on the prime, and quantified it to 5.3 gallons. what if the tank is full?
  3. El Dobro
    El Dobro A Member
    7,102
    3,282
    Let someone try it and see what happens.
  4. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    No because I start and run the ICE up to normal operating temperature at least every 2 weeks and add a little more gas each time when I go on a typical drive of 80 miles. I feel since I keep a minimal amount of gas in the tank and run the ICE this often there is no damage or gumming.
    Prius from Dad likes this.
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    We go out of town about once a month, and that takes care of stirring up the ICE components, and reminding me where the gasoline station is.
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    1,711 mile trip over the weekend, so no concern about gas here.
    80 mph for a bulk of that travel. Faster passing at times. 103 mph briefly, because resistance was futile.
    50.1 MPG overall average displayed, without any recharging.
    In other words, just go on a trip from time to time.
    #26 john1701a, May 9, 2017
  7. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    The closely-related question has come up, of "how often do we really need to change the oil, given that you rarely use the ICE."
    That's an involved question, but it's worth considering that oil breaks down partly by oxidation, which is just a function of how long it's been in the crankcase. Heat breakdown (more-or-less depolimerization) is the other main degrade mechanism, and is largely a function of miles on the ICE.
    So the oil will break down over time even if you don't use the ICE much. More-slowly, certainly, but it will fade over time.
    If you really do never use the ICE, then well, I guess you could get away without any oil changes, conceptually. I suspect most people will find it hard to really never use it though.
    iPhone ? Pro
  8. MattStevenson
    MattStevenson Member
    57
    35
    US
    The heat in my Prius Plug-in still requires heat from the ICE coolant. It would be possible if you kept yourself in a warm climate.
  9. mr88cet
    2,313
    1,335
    Austin, TX
    Since the P.Prime, unlike the original PiP, has a battery-powered heat pump, it can heat the cabin without starting the engine. Obviously though, that cuts into you battery life, making it even harder to achieve that no-ICE hypothetical.
    iPhone ? Pro
  10. john1701a
    12,840
    5,312
    58
    It can be run off the grid to pre-condition the cabin.
    There is also a battery-warmer, which prevents the normal impact freezing temperatures have with EV driving.
