A50/A51 junction connector location
Discussion in 'Gen 3 Prius Technical Discussion' started by ErikJ, Jul 24, 2018.
  1. ErikJ
    ErikJ New Member
    23
    Palo Alto, CA
    2015 Prius Plug-in
    Hi everyone!
    I am trying to find a place to tap the stop light signals, and it appears all the stop light inputs/outputs run through these 2 connectors. Does anyone know where they physically are located? All the wiring diagram I have shows is "left end of dash".
    Thanks!
    Erik
  2. ChapmanF
    18,555
    You're looking at the Location & Routing pages, the ones that look sort of like this?
    I had some more information in the post where that came from about finding stuff effectively in the diagram viewer.
    -Chap
  3. ErikJ
    ErikJ New Member
    23
    Palo Alto, CA
    2015 Prius Plug-in
    Hiya Chap,
    Unfortunately, I don't have a login to TIS, I have access to ProDemand and find that to usually be sufficient to track things down, but apparently not in this case. I did locate the Stop Light Control Relay, however it's in a very difficult to access location without complete disassembly and following the wires back from it just leads me to a giant harness.
    Thanks,
    Erik
  4. Alberich101
    Alberich101 Junior Member
    Hungary
    2013 Prius Plug-in
    Dear Erik
    did you manage to find it eventually?
    I am looking for the same junction
    thx
    peter
  5. Tom Mayor
    Tom Mayor Junior Member
    55
    Orlando
    I am curious if you found a way to access to the a50/a51 connector or the relay yourself ? I have to go through that cause of a fuse blown issue. It could be super helpful if you could tell me how was the process to access to the relay or connector and how easy it was to disconnect these parts? I'm an amateur. Thank you and happy holidays!
