ABC News reports on acceleration problems
Discussion in 'Gen 2 Prius Main Forum' started by priusincc, Nov 3, 2009.
  1. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    I get that too. I can be gliding, then lift off the gas pedal completely, then when I press the brake pedal get a slight feeling of acceleration. I seem to recall reading somewhere that no-pedals regeneration is done with MG1 while braking with the brake pedal is done with MG2, though that could have been someone else on here. If that is the case, the slight hesitation could be while it switches from one to the other.
    I think it's also subtly transferring control - the brake pedal is read by the Skid Control ECU while the accelerator is read by the Hybrid Vehicle ECU. When you brake with the brake pedal, the Skid Control ECU tells the HV ECU how much regen it wants - perhaps there's a moment where what it tells the HV ECU is actually less than the HV ECU was already doing on its own. As a result it decelerates less, which feels like an acceleration.
    You would think that the HV ECU would ignore such a signal but in the case of controlling the braking force over bumps, the Skid Control ECU wants to keep complete control (ABS on friction brakes) and eliminate regen entirely.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Yes. It happens if one of the front tires loses traction. Normal braking in a Prius is done regeneratively through only the front drive wheels. If one of them slips for any reason - ice, bump, whatever - the traction control system senses this and switches to ABS friction braking on all four wheels.
    The loss of traction and transition to ABS friction braking produces a very short interval of reduced braking. When you are already braking, a reduction in braking feels like forward acceleration. You don't really accelerate forward since you are still slowing down, but it feels like acceleration since you are not slowing down as fast. After the short transition braking works as it does in any normal car.
    Tom
  3. sambojoho
    sambojoho Proud conservative
    92
    23
    Ohio
    There is a way on the Prius to shift into neutral without much thought, delay, or fiddling around with the shifter. Simply press the Park button while driving and it will kick you instantly into neutral. I have hit the park button a couple of times accidently while driving...
