Abnormal wearing only on rear tires
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by galileofigaro, Apr 2, 2021.
  1. galileofigaro
    galileofigaro Junior Member
    37
    2015 Prius Plug-in
    Alignment done in July 2019 at a Toyota dealer. Only rear tires wearing on the inside, front tires look fine.
    This PIP has a reconstructed title, maybe the accident (it wasn't mayor) has something to do with the problem or the Toyota dealer didn't align the tires properly. I recently noticed this so I went to the dealer but warranty had expired, asked me to pay $90 for checkup and then some more to fix the problem.
    Anybody that can make an alignment reading I am attaching?
    Due to the pandemic I didn't drive the car for several months so this problem took around a year to surface since tires were installed brand new at a Costco the day before alignment was done.
    What do you think about flipping the tires so the worn part faces outwards? This is in order to make them last longer, otherwise I'd be installing new ones in a couple of months.
    #1 galileofigaro, Apr 2, 2021
  2. Mendel Leisk
    42,343
    It’s normal for rear tires to wear faster at the inside edge of the tread, because of the neg camber on the the rear. It shouldn’t be pronounced, and if you rotate them front-to-rear it’ll even out.
  3. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The alignment numbers change slightly when you get back in the car. But instead of paying Toyota the $90 and then some to look into it, just pay the tire store in your area the $90 to reset the alignment. The shops around here in my area will do a courtesy inspection to see if it’s possible to do a satisfactory alignment before doing any adjustments.
    privilege likes this.
  4. Mendel Leisk
    42,343
    Rear camber is not easily/cheaply adjustable, if that’s the cause.
    The title gives me the impression the wheels are not being rotated.
  5. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Maybe the car has settled on the rear springs, or there is a mechanical issue throwing off the rear camber. Hub assembly’s could be worn out.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I found this video on the SPC Alignment website. They actually have a rear toe/camber shim for the Prius. Pretty cool to see the process that iOS followed.
  7. Bucky35
    Bucky35 Junior Member
    37
    NorCal
    I used these SPC shims to fix the rear wheel alignment on my last 2 Prius cars. Both had crap rear alignment from new. Major shortcoming and I hammered Toyota on my last new owner survey. Total crap engineering on a beam axle.
  8. Mendel Leisk
    42,343
    Using those shims requires taking off the wheel bearings? It’s almost tempting: just putting a carpenter square against them and doing a little trig, mine seem to have disparate camber, over spec on one side and near the low end on the other. Shimming is something they could have done at the factory?
  9. bisco
    52,848
    i seem to remember bob wilson doing this.
    anyone seen the o/p? seems to be a bit hit and run. maybe explains the salvage title
  10. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    It's a limitation with torsion beam suspension, and the problem is not limited to Toyota - it's a fairly common issue with the 1st gen Nissan Leaf too. Gen 4 Prius has double wishbones on the rear which are adjustable, so it's no longer a problem.
