About undercarriage shield
Discussion in 'Gen 3 Prius Accessories and Modifications' started by burebista, Aug 20, 2020.
  1. burebista
    burebista Active Member
    189
    130
    Romania
    My wife took a paving stone under the car. When we're at home I take a look under the car and everything looks fine, shield is intact and no damage to anything.
    Also I saw that I'm completely missing that door for changing oil/filter.
    But now my wife wants a metallic shield. I found one here, looks pretty solid (2mm or 1/16 inch thick, galvanized, anti-rust treatment) for 80 bucks.
    But I saw that original shield has some sound/vibration/whatever protection. Like this (picture not mine, borrowed from priuschat).
    That metal shield is just bare metal so I want to put something for dampening sound/vibrations but I don't know what to look for. :(
    So I'm asking you for some ideas and I'll look here in Romania for something similar.
    Thanks.
    PS. Also I want to mod that shield to make a hinged door similar to this.
  2. Kenny94945
    Kenny94945 Active Member
    861
    437
    Sausalito
    2016 Prius v wagon
    In USA there is a product called Dynomat (typically used for sound deadening on interior surfaces - under capets, on inside of doors).
    Maybe a Romanian home imporvement store will have a furnace insulation product that will work?
    Perhaps the main concerns would be flamibility and oil absorbtion.
    I think Dynomat would be safe in both those concerns, but I donlt know for sure.
    Yet, can your transfer the OEM plastic sheild insulation to your new metal shield?
    Broken oil change access panel, known issue, your hinge solution is the cure.
    Have fun with your project.
    burebista likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Unless you tested the shield and found actual vibrations, I’d financially invest elsewhere. This is for aero purposes, it shouldn’t vibrate unless it's damage or pins aren’t properly snapped in place.
  4. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    So she can drive over anything she wants and it can take a beating (y)
  5. burebista
    189
    130
    Romania
    OK, I found a Dynamat product here: Dynaliner. Heat insulation, water/oilproof but it has a hefty price, almost 70 bucks. :eek:
    Good point. I'll pass the insulation then, watch how it goes as it is and if I hear something I'll think about then.
    Yeah, she's the driver, she's the boss. I'm only the guy who keeps the car up and running in a good shape. :)
    Thanks all for your input. (y)
