ABS actuator- bleeding procedure
Discussion in 'Gen 2 Prius Technical Discussion' started by Emiley Juarez, Mar 2, 2020.
  1. Emiley Juarez
    Emiley Juarez New Member
    Mississippi
    I have a 2008 Toyota Prius. I just replaced and installed a new ABS actuator and I’m wondering if there is any way I can bleed it without a computer ?
    I haven’t tried turning it on, I just want to make sure I don’t skip any steps...
  2. Aegean
    Aegean Active Member
    449
    199
    Alexandria VA
    I have done the actuator bleeding with techstream and it’s fairly straight forward. Since the process involves running individual motors I doubt it is possible to bleed it without techstream. The good news is that the connector is just $20-$30 and software easily installed on a laptop.
    Emiley Juarez likes this.
  3. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    Where do you get the techstream software
  4. Emiley Juarez
    Mississippi
    ^I’d like to know the same thing !
