ABS actuator motor replaced teachstream software error air bleeding fail
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bcmullen95, Jan 25, 2020.
  1. Bcmullen95
    Bcmullen95 New Member
    Replaced the ABS pump with a used one. If the one I purchased has the same or more DTC codes, would this indicate it is a bad ABS pump. I have attempted to bleed using the techstream software, but I get Air bleeding fail. Any in for this or links to the info would be greatly appreciated.
  2. Bcmullen95
    I have realized I am having an issue with either the techstream software or the mini vci cable? Anyone had success with a mini vci cable for bleed ing the abs module after replacement?
  3. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Have you tried doing it without techstream and see if it works?
  4. Elektroingenieur
    2,515
    3,288
    Three Touring
    You wouldn’t be the first person to report problems; see this thread about a later model, for example.
    The Repair Manual (more info) cautions specifically against this, since the bleeding will be incomplete.
