ABS actuator replacement...Pick-N-Pull or Ebay?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tynyyn, Oct 8, 2022.
  1. Tynyyn
    Tynyyn Member
    109
    30
    Bella Vista Arkansas
    I've figured that my ABS actuator has bit the dust and now in the process of deciding to purchase a replacement actuator. Looked on Ebay, their prices range around the $400-$500 range. That got me thinking about going to a Pick-N-Pull and getting one for around $200. That sure beats the heck out of the dealership price for part and labor.
    My question is .......Do you think the Ebay actuators are any better/more reliable than the PNP parts? Seems to me that getting a dud at either place is a possibility so why not go for the less expensive option? Heck, the sellers on Ebay probably went to a PNP and got their actuator, doubled the cost and then put it up on Ebay.
    Is my thinking in the realm of possibility? Doing any replacement with a used actuator is sketchy because you do not know the actual mileage of the PNP car, thus you might be pulling a acutator out of a Prius that has 250K miles on it and the actuator might have only 10K miles of life left in it. Do acutators have a life expectancy?
  2. JC91006
    16,915
    8,633
    These parts will need replacement as they age, they all fail eventually. Depending on the condition of your car, you may want to get a new part from Toyota. That will at least last another 10 years.
    This is quite an extensive time consuming repair, you probably don't want to find out after 5 hours of hard labor that the part is no good.
