1. IBGPRIUS
    IBGPRIUS Junior Member
    I have toyota prius 2006. Yesterday, January 1, 2018, while driving car, I suddenly hear a squeaking sound and on display I saw "!" and "(ABS)". I turned the engine off and opened the manual. The manual says to stop and contact the toyota dealer. It was January 1 and I thought that I have a Happy New Year from my car. I decided to try to turn the engine on again. When I turned engine on there was no alert neither sound no display. The car behaved normal and brakes worked OK. I thought that it probably was computer malfunction. Today I contacted dealer and they told me if car is behaving normal there is nothing that they may check.
    Is there any body who has a similar experience?
    52,751
    it may have stored a code, but you would have to take it to the dealer. how many miles on her?
  3. IBGPRIUS
    The car has almost 117000 ml.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    THAT is a bunch of BS.
    There are several things that they could and should check.......IF they had a real mechanic on staff instead of just a bunch of code reading monkeys.
    The noise would tend to indicate that one of the brake calipers was stuck, maybe temporarily.
    I think you should take this opportunity to have a COMPLETE brake inspection. That might show things that need to be done.....like pads, calipers, fluid change and maybe rotors (but not likely rotors).
    IF that has not been done in the past 5 years or so, it might set you back more than $500.
    How important are your brakes to you ??
    davecook89t likes this.
  5. bisco
    52,751
    is it cold there?
  6. IBGPRIUS
    Thank you, I'll contact another dealer.
  7. ChapmanF
    18,941
    Would you describe this "squeaking sound" as something like parts rubbing together, or more like a consistent, high-pitched beeping?
    If you search here, you can learn how to get the brake computer to blink out its diagnostic codes using the dash lights, using just a short piece of wire. You don't need any special code reader for that (though you can get more in-depth information if you have one). That means you can be ready to find out what that computer is trying to tell you, immediately, the next time it tries. Someone here may recognize the codes if you post them (though you can always look them up yourself in the Repair Manual, too.)
    -Chap
  8. IBGPRIUS
    It is very cold, the night before last was 3 F.
  9. bisco
    52,751
    maybe a frozen caliper that thawed out. might be a good idea to look things over in a warm shoppe.
  10. IBGPRIUS
    Thank you Chap, the noise was high-pitched, it wasn't caliper because the noise continued even when I stopped the car, I'm not 100% sure that the noise was beeping, maybe it was continued noise. This I don't remember exactly.
  11. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    When the car stopped as you said, was the noise coming from the hood area, since you've confirmed that noise wasn't metallic kind of?
    And for the malfunction lights not coming back again, it could be some kind if intermittent ECU freaking up, or, while the lights hasn't returned, might be because you've got to complete some certain drive cycles before the fault codes that logged the code would resurface.
    Another possibility could be that the noise was coming from the abs pump.
    I have had an experience with a hihy with a constant, maybe barking noise you might say with all the lights on board the dash
  12. ChapmanF
    18,941
    I asked because the ABS alarm is a continuous high-pitched beep. It sounds like that's what you were describing, and you may have misdirected Sam a little just by calling it a squeak.
    The computer doesn't use the alarm sound for all of the trouble issues it can detect, but only for a handful of the more serious ones (in the repair manual, there should be a chart of the different trouble codes, including which ones sound the alarm and which ones don't). Even if you don't get the display again, we know it was one of that handful of codes.
    One of them would be taking too long to pump up the proper brake pressure, or the electric pump drawing too much current. It has been very cold lately, which can legitimately make a lot of electric-motorized devices slow down and draw too much current, so if you don't see recurrences, you might chalk it up to that, and have no issues later when the weather is warmer.
    If the lights come on again, especially with the alarm sound, I would read the codes right away.
    -Chap
  13. IBGPRIUS
    I'm not sure where the noise was coming from, it sounded to me like from dash area, but there is nothing to make a noise from dash. I wish it would show a code, but it show only exclamation sign and (ABS). The noise was a high-pitched but not very high.
  14. IBGPRIUS
    Thank you Chap, it sounded that you are right and I'm sorry for "squeak" noise. I just not familiar with all the term that use in this case. I don't have a repair manual, only the manual that Toyota supplied with the car.
    Thank you every body for help.
  15. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I suspect the noise is from the abs pump positioned at the driver side behind the inverter.
    That inverter might be telling you, "Sir, start preparing for my bill"!:D
  16. ChapmanF
    18,941
    Yes, that's where the alarm is located.
    You get the code(s) by using a small jumper wire between two pins (Tc and CG) of the diagnostic connector under the dash, then counting blinks of the brake / ABS / VSC lights on the dash. Without the jumper, the lights simply light up, to tell you there are codes.
    Details are in other threads on PriusChat, and in the Repair Manual, of course.
    A code reading tool, such as they have at the dealer, can retrieve more detailed codes, and a lot of other information describing what was going on at the time.
    techinfo.toyota.com exists to solve that problem. :)
    -Chap
  17. IBGPRIUS
    Thank you everybody, I learn something.
  18. WindChaser
    WindChaser New Member
    Paia, HI
    Same for me - diagnosed with ABS problems. Occasionally get high pitched scream when starting the car with ABS/VCS lights. Scream goes away after 10 seconds or so and warning ligthts go off. Car is fine after (although there are other ABS related issues).
    Very distinct sound though - really sound like a barking or chicken squawks.
    +++ Rick ---
