ABS and other bulbs are on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TharakaD, Jul 9, 2015.
  1. Patrick Wong
    18,214
    6,531
    Have you removed the cowl tray that runs across the rear of the engine compartment? If not you need to do that. This requires removing the windshield wiper arms, removing the cover over the tray, removing the windshield wiper motor, then finally removing the tray. Disconnect the 12V battery first, by removing the negative cable where it bolts to the body.
    Then you should be able to find the skid control ECU which is part of the brake actuator assembly. The brake actuator assembly has multiple steel brake lines connected to it.
    TharakaD likes this.
  2. TharakaD
    TharakaD Member
    137
    Colombo
    Thanks Patrick, much appreciated
    I did remove the cowl and I think I located the actuator (picture attached above post). But couldn't locate ecu. Let me try more
    What do you think about that abnormal sound I heard near the brake pedal (attached above post)?
    Now I'm getting bit scared ..
  3. Patrick Wong
    18,214
    6,531
    The picture you posted was fuzzy and I could not see if any steel brake hydraulic lines are bolted to the part. If you do not see this, keep looking.
    The sound is abnormal. I don't know whether it is caused by the braking system. Now that you have the cowl removed, maybe you can pin down its source by listening at the engine compartment, if you get someone to help you depress the brake pedal or do whatever is required to invoke the sound.
  4. TharakaD
    TharakaD Member
    137
    Colombo
    Couldn't find time still to do the remainder
    BTW, I was just looking for skid control ECUs on eBay and amazon there are lots available but all for gen 2. Not for gen 3. That's shocking for the possible next step
  5. TharakaD
    TharakaD Member
    137
    Colombo
    i know its been i while, due to travelling to US and back.
    the car didnt move at all while is was away for 10 days. and now the lights come up about once a week.
    so that means i still have the problem
    just wanted to confirm is the attached picture correct for the skid ECU, and the pin slot.
    so i can do the required with multimeter
  6. Patrick Wong
    18,214
    6,531
    Yes, I believe you have located the brake booster with master cylinder, which includes the skid control ECU.
  7. TharakaD
    TharakaD Member
    137
    Colombo
    I thought it should be a neat work. With a plug fitting a socket. Now have to work through each wire...
    Wish me luck folks...
  8. TharakaD
    TharakaD Member
    137
    Colombo
    Couldn't find the pin 34 & 35 since didn't know how to start counting.
    The diagram was different from the actual. Pls see attached.
    Pls let me find the pins.
    After I fixed the harness connector again to go to work now dash shows yellow triangle and say check hybrid system.
    Also that unusual sound near brake piston seems too obvious, like a vacuum sound. I'll try to attach that also
  9. bisco
    52,927
    good luck!(y)
  10. TharakaD
    TharakaD Member
    137
    Colombo
    Thanks bisco...
  11. Patrick Wong
    18,214
    6,531
    1. Since you have a JDM model, maybe it uses a different skid control ECU and a different wiring harness. I assume your repair manual came from the TMS USA techinfo.toyota.com website?
    2. Did you try to retrieve the DTC, then clear them to see what happens?
  12. TharakaD
    TharakaD Member
    137
    Colombo
    Thanks Patrick.
    May be I should check, is there a different manual for JDM model
  13. TharakaD
    TharakaD Member
    137
    Colombo
    hi patrick
    i took the manuals from
    Toyota Service Information
    but there was nothing special for JDM.
    Does above attached connecter picture look similar to your manual?
    it has 42 pin-slots, but config may be different; so what pins to check for resistance is a question?
    Do you think this is the right connector/ or have i taken something else.
    all i can say; when i switched to ready mode, with disconnected harness.
    there was no pressure on brakes. it was raw brakes, wouldn't able to stop a running car.
  14. Patrick Wong
    18,214
    6,531
    My 2010 manual has a drawing of the skid control ECU connector which matches the photo of your wiring harness connector.
    The skid control ECU assembly is designated A58 and the part number is 90980-12828.
    Referring to your photo, pin #1 is the large pin in the bottom far right. Pin #15 is the medium sized pin in the bottom far left. The little pins on the bottom row are numbered #3 (on the right side) through #14 (on the left)
    Pin #16 is above pin #3 while pin #27 is above pin #14, regarding the little pins on the row above the bottom row.
    Pin #28 is the medium sized pin above pin #15, far left.
    Pin #29, upper far right large pin, is above pin #1.
    The little pins on the top row are numbered #31 on the right and end with #42 on the left. That is where you will find pins #34 and #35. Measure the resistance across those pins of the wiring harness connector.
    There is no need to turn the car on while the wiring harness connector is removed. The 12V battery should have been disconnected prior to removing that connector. Using Mini VCI, you will need to clear whatever codes were logged, after you reconnect the wiring harness connector to the skid control ECU.
    #54 Patrick Wong, Aug 21, 2015
  15. TharakaD
    TharakaD Member
    137
    Colombo
    Thanks loads Patrick, you're the savior.. !!!
    I switched on the car to see, whether its drivable as i have to come to work today.
    hopefully tonight [now its 6:00PM] i can figure whats the issue.
    so i will keep you updated... <hoping issue to be a minimal>
  16. TharakaD
    TharakaD Member
    137
    Colombo
    Ok guys
    Now I have to find a Skid control ECU or entire assembly
    And instructions to replace it
    because it was 62.3Ohms
  17. TharakaD
    TharakaD Member
    137
    Colombo
    Or should I just try cleaning socket & connector well before connecting it.
    So what do you think the best way to do it
  18. Patrick Wong
    18,214
    6,531
    The 62 ohm reading shows that the skid control ECU is able to connect to the other two ECUs which each have 120 ohm terminators across the comm line. Two 120 ohm resistors in parallel will measure ~60 ohms. Therefore, the failure of communication is probably due to the ECU.
    However, you can try cleaning the ECU terminals. Buy a can of electrical contact cleaner and spray the wiring harness connector as well as the ECU terminals. Or if you don't have that easily available, use 91% isopropyl alcohol that you can buy from your local drugstore (at least this is the case in the US) and use that to clean the terminals, using a Q-tip. Do not allow any cotton residue to remain on the terminals.
    Then reconnect and see what happens. Use Mini VCI to clear any stored DTC and then drive the car around.
  19. TharakaD
    TharakaD Member
    137
    Colombo
    Vacuum cleaned it,
    then used isopropyl available at home
    Again vacuumed to remove any cotton residuals
    Fixed the connector
    Went to ready mode, had few bulbs coming on
    Cleared the dash lights with obd pin short and brake pushes (all went off, or should I use the scanner to clear)
    Now have to use and see.
    Will fix wiper stuff and cowl.
    It's just two wires we checked. What if any other wire has a problem....!!??
  20. Patrick Wong
    18,214
    6,531
    I suggest you use Mini VCI to make sure no DTC are logged and clear anything in history.
    Since the only code you previously identified is U0129, lack of communications is the only known issue and the comm is via the two pins.
    Drive the car and see whether the same DTC reappears or if a new code is logged.
