ABS and other bulbs are on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TharakaD, Jul 9, 2015.
  1. TharakaD
    TharakaD Member
    137
    Colombo
    Just completed 350km drive.
    ECO bulb just above the fuel consumption number does not light up. (see attached)
    No DTCs.
    #101 TharakaD, Sep 11, 2015
  2. Patrick Wong
    18,214
    6,531
    200 miles without logging a fault code isn't bad.
    The ECO light not coming on is minor. Is that a recent change?
    I would be more concerned about what fuel economy your car can produce.
  3. TharakaD
    TharakaD Member
    137
    Colombo
    It was 20.5 km/ l.
    That's not normal
    Used to be 23-24
    So how to sort out eco bulb
  4. Patrick Wong
    18,214
    6,531
    20.5 km/l = 48 miles/US gallon which isn't terrible.
    I don't know what to do about the ECO light, you probably would have to disassemble the dashboard sufficiently to remove the central display assembly. Maybe if you clean the wiring harness connections, all lights will resume normal operation.
    TharakaD likes this.
  5. FrankB
    FrankB Member
    117
    53
    What about the power and EV buttons?
  6. TharakaD
    TharakaD Member
    137
    Colombo
    Eco, power, ev & normal modes are working
    But in eco mode in eco rpm range eco bulb doesn't come up.
    Pls check my attachment in above post
    Do you also have the same problem?
  7. FrankB
    FrankB Member
    117
    53
    No, I don't. I misinterpreted the problem, sorry. I now see the ECO green light where you are referring to the ECO blue graphics.
  8. TharakaD
    TharakaD Member
    137
    Colombo
    hi patrick
    I had a brake oil leak near drivers area [probably near ecu]
    and showing C1202.
    wondering have they not secured the ecu hoses well
  9. Patrick Wong
    18,214
    6,531
    Apparently not.
  10. TharakaD
    TharakaD Member
    137
    Colombo
    got an ECU from ebay, collected by myself from USA and fixed myself
    Issues faced:
    same part no, but it wa WP_20151028_001[1].jpg s a LHD ECU would not fix 100% to my JDM
    so had to turn one steel hydraulic tube [front drivers side wheel connecting] manually and fixed
    C1203, seems like due to incorrect ECU...
    anyway after few times of calibration; everything seems to be fine now..
    my mileage also seems to have recover; however too early to comment
    Patrick Wong likes this.
  11. Mendel Leisk
    42,383
    ECU equals Electronic Control Unit (computer), but I'm stumped on LHD: translation?
    Ahh: Left Hand Drive!
  12. FrankB
    FrankB Member
    117
    53
    left hand drive?
  13. TharakaD
    TharakaD Member
    137
    Colombo
    yes: LHD= Left Hand Drive
    so driver sitting on Left hand side of the car
    in here its RHD thats why JDM [Japanese Domestic Model] is popular
