ABS Anti Lock Brake Pump Actuator - Seal question
Discussion in 'Gen 2 Prius Technical Discussion' started by eluo, May 13, 2026.
  1. eluo
    eluo Member
    122
    71
    Commack, NY
    Looking to buy a used Brake Actuator off eBay and noticed this picture after I made the purchase. How important is this seal? It looks compromised.
  2. eluo
    eluo Member
    122
    71
    Commack, NY
    The seller was nice enough to cancel my order. But still wondering if this would have been bad because if the compromised seal.
  3. Tombukt2
    Tombukt2 Senior Member
    13,816
    2,505
    Durham NC
    That seal is not compromised . Is a cover. There's access points under there. It wouldn't have heard a thing you would have installed it and done your business and bled the brakes.
    eluo likes this.
  4. eluo
    eluo Member
    122
    71
    Commack, NY
    I saw others photos on eBay where the cover was concave as if there was negative pressure. Thought it was a seal of some type to keep low pressure gas or liquid from getting out.
    Thanks for confirming that it should not be a factor in functionality.
    I'll continue my search for another decent looking brake actuator.
