ABS, brake and traction control lights on, $3600 to replace the brake pump and cylinder?
Discussion in 'Gen 3 Prius Main Forum' started by Jaydoc, Jul 25, 2020.
  1. Jaydoc
    Jaydoc Junior Member
    30
    Birmingham
    Hi all
    My 2010 Prius with 180k miles on it has had regular maintenance done at a nearby Toyota dealership. Recently it had an issue with an oil leak that cost me $2000 or so to get taken care of.
    Two days ago I was driving during a thunderstorm and the ABS, brake and traction control warning lights came on and the brakes just didn't feel right after that. So I took the car in to the dealership and they are telling me that the car is "undrivable" and needs to have the brake pump and cylinder replaced, for a total cost of $3600.
    I bought this car for $9000 4 years ago and it has held up well so far, except that oil leak and now this.
    I am not sure if I should
    a) Do the repairs at the dealership
    b) Get the car towed to another place for a second quote
    or
    c) Just sell the car for a pittance and get another newer used car!
    Any advice is much appreciated. Thanks.
  2. ChapmanF
    17,352
    If you paid the dealership for diagnosis, they should have given you the diagnostic information they retrieved from the car's computers. If you could post it here, we might have better advice.
  3. Grit
    Grit Senior Member
    6,456
    4,189
    Wilkes Land
    D) Check if this is covered by zjb.
    51,155
    head gasket is next. when looking for a used car, due diligence is of utmost importance
  5. Jaydoc
    30
    Birmingham
    C1391 accumulator malfunction was what the diagnostics showed according to the tech there. Not sure if this is something covered by any recall.
  6. Jaydoc
    30
    Birmingham
    How do I contact Toyota about this? Thanks.
  7. ChapmanF
    17,352
    You can read the "customer support program details" here yourself, compare the the year, mileage, and trouble code(s) present on your car, and have a pretty good idea from that whether it's worth following up with a dealer.
  8. Johnny Cakes
    Johnny Cakes Senior Member
    1,042
    776
    Virginia, USA
  9. Krall
    Krall Member
    125
    37
    NY
    I had that with the big yellow caution light which I chose to ignore. Eventually it was like trying to stop a Fred Flinstone vehicle, very much seat of your pants.
    The dealer wanted a similar ransom amount. Luckily I was referred to a mechanic who did a little research and found he could use the parts from a used 2011 or 2012 which and an improved version of those parts. It was like $1200.
    I think there was a bulletin at the time so he had me call customer care to see if they’d cover it. They wouldn’t, but if I remember they recently did a recall on the issue for 2010s.
