Abs,brake and traction control lights on
Discussion in 'Gen 3 Prius Main Forum' started by Jack cheney, Jul 31, 2020.
  1. Jack cheney
    Jack cheney New Member
    Fla
    Took the Toyota dealer and they replaced the ABS pump the brake booster pump and the actuator and we filled with fluid this is a recall for a warranty part as long as you have less than a hundred and fifty thousand miles and you Prius is less than 10 years old the repair cost absolutely nothing
  2. varun singh
    varun singh Member
    113
    Wayzata
    Same here too, how frequent is now the pressure booster running, since the replacement I see for every 1-3 brake pedal presses I can hear it running.
    Would appreciate your response back.
    52,878
    great company
