ABS BRAKE ISSUES, Shutdown of Regen
Discussion in 'Gen 2 Prius Technical Discussion' started by odinaf, Feb 8, 2019.
  1. odinaf
    odinaf New Member
    Tacoma, WA
    So I bought a 05 Prius From our shop, hybrid battery is good, each cell is at 15.3 v. But I noticed a few issues. Only the Left Side Regen system is working in any condition. The parking brake (manual brake) is broken off, I'm trying to replace it and alldata says its only 0.8 hours to do, but it looks like the brake assembly comes off and I can't see doing it without ripping the whole dash out.
    This is leading to another problem which is C1343 Fault in Hydraulic system RR.
    Someone did the rear brake prior and I was thinging air in the system, but I can't get the brakes to bleed with scan tool until the parking brake is fixed.
    Thoughts, tricks?
    52,804
    welcome!
    the regen takes place in the tranny/inverter/ battery. there are no sides.
    if you are going to diy, best to get a copy of tech stream, and a subscription to the service manual at tech info.toyota.com
    all the best!(y)
  3. odinaf
    odinaf New Member
    Tacoma, WA
    So when braking if you look, I only have left side regen, I'm wondering since the fault is on the right side of the car if the right regen has been disabled. Which would exsplain the 35mpg I'm getting even with a engine air block. It seems like the car is having a issue charing the hybrid batteries but each cell is reporting a average 15.6v charge.
  4. ChapmanF
    18,980
    I think I would compare the "Solus Edge" PID definitions to those of Toyota Techstream, before I'd become fully convinced that my car had left and right flavors of regen.
    fuzzy1 likes this.
  5. fuzzy1
    10,690
    I must question whether the FR and FL mean Right/Left at all.
    As others have pointed out, Regen has no Right or Left. It all happens in a single center unit.
    Complete loss of regeneration -- center, right, left, whatever -- cannot explain 35 MPG.
