ABS/brake lights and codes C1241 C1391 U0073
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Kemmotar, Oct 26, 2025.
  1. Kemmotar
    Kemmotar Junior Member
    Kentucky, USA
    2014 Prius v wagon
    This is my wife's 2014 Prius V. She recently told me all the brake lights on the dash had lit up. I drove it, and brakes work, but the pedal feels a bit soft. Fluid reservoir is full. Pulled codes with the following results:
    C1241 low or abnormally high battery positive voltage to the skid control (ABS) ECU
    C1391 abnormal leak in the brake actuator's accumulator
    U0073 seems to be related to ABS ECU communication error
    So far I've checked all the fuses that I can find that might be related to this problem, and have checked the 12V battery voltage (>12V with car off, >14V with car running). All fuses were good.
    I do see evidence of rodents (poop and seeds), but can't find any obvious rodent damage to wiring harnesses. Any thoughts on specifically where I should check for wire damage, or other diagnostic procedures would be appreciated!
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,996
    6,893
    Texas Hill Country
    Often a failed brake booster (master cylinder)
    52,773
    sometimes there is corrosion at the ecu pins. sometimes it's just a weak 12 volt battery.
    it could also be hidden rodent damage
    Air_Boss likes this.
  4. Kemmotar
    Kentucky, USA
    2014 Prius v wagon
    This car is in the date range mentioned in that document.
    I cleared codes, and only the C1391 code returned. The brake booster also cycles every few seconds when the car is on, so I'm thinking that is the issue.
  5. rjparker
    10,996
    6,893
    Texas Hill Country
    If the brake booster program still applied on your car Toyota would change it free based on that code.
  6. Air_Boss
    Air_Boss Senior Member
    4,245
    1,195
    New Yawk
    Unless it was beyond the ten years from initial date of service time limit, or Toyota offered a good will extension.
