ABS break pump failure
Discussion in 'Prius v Main Forum' started by Eric mbaabu, Aug 2, 2020.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    I got a notice in the mail stating that the actuator on my 2012 v is covered for 10 years or 150k miles. Since my 9 year old v is only half way through the 25k mark, I feel that I have no need to worry.
    Air_Boss likes this.
  2. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Do you know how i could check that for my 2012 Prius C? i would like to know if the actuator is under warranty.
  3. ChapmanF
    19,041
    You can find all of the service campaigns that apply to your car under the SC tab on TIS, as described in this post.
    The Toyota Owners' site might also have access to the information somehow; I don't know that for sure.
  4. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    I will take a look, thank you very much.
  5. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Try 1-800-331-4331
  6. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Pump was running every 10 seconds.....didn't matter if stopped or moving even with engine off.. Always change the trani fluid
  7. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    What about brake fluid bleed? you did it yourself? And before filling the transaxle with new fluid you have to clean the filling hole, otherwise dirt and other contaminants will get inside and could cause damage. I was thinking about changing mine since it's over 100,000 miles and still have the original fluid. First need to buy a pump for that.
  8. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    You remove the top bolt first on the trani....... you just let it run out.....the bottom.... use long hose connected to a funnel then add fluid until it runs out the top hole. I used techstream to bleed the brakes.
  9. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    Good, that sounds very simple, obviously the car needs to be leveled.
    And how much you paid for techstream? and was that the first time for you using it? i think that installing the brake actuator myself and paying for techstream to bleed the brakes is going to be less expensive than letting the dealer do it for me.
  10. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    The software was 20.00 or less I think on ebay. You need the USB to Jack under the dash cable.
    BD2
    Sonic_TH likes this.
  11. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    I see, thank you very much for answering. This will make it easier when the time comes.
  12. tonni
    tonni New Member
    Pakistan
    I'm really sorry to hear about the issues you're facing with your Prius V and the pending recalls. It’s good that you checked the global Toyota recall database and pushed your local dealer to at least do the software upgrade. However, I agree that the ABS brake pump and actuator replacement is a serious issue that should not be ignored, especially since it's part of an official recall. If the local dealer is still refusing to act, I would recommend reaching out directly to Toyota's head office in Japan through their official contact channels, or even escalating the issue through Toyota's regional offices that handle Africa. Sometimes, when dealers realize that the issue has been raised with the manufacturer, they are more willing to cooperate. Also, putting everything in writing and keeping a record of your communication with both the dealer and Toyota can help strengthen your case. I hope you get the help you need, and it would be great to hear from others who may have dealt with similar challenges.
    Tim Jones likes this.
