ABS Codes C1253, C1364, C1365-Corrosion?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jerry G., Nov 8, 2016.
  1. Jerry G.
    Jerry G. Junior Member
    78
    Keaau, Hawaii
    Hi all,
    So my knowledge of ABS systems is limited, but I have scoured the forum and researched the whole ABS issue and as it stands I am questioning whether the ABS pump is bad. I can hear the relays click and turn the pump on and off, but the pedal looses pressure if depressed, and upon the pump coming on I can feel the pedal coming up slowly.
    I say this because the ABS-1 fuse was blown (10a in place of a 25a) and upon disassembly of the pump connector, I saw corrosion on some of the pins and connector, which could likely be the issue?
    Prior to tearing down to the pump, I purchased a good used unit from a reliable Prius parts source here in Rancho Cordova, Ca.that I get my parts from. The original pump has the newer flat top as does my replacement. Million dollar question is do I go through the trouble of replacing the existing pump, or do I chance cleaning the connector/plug and reassemble things again to test it to see if it works, all to avoid the replacement and bleed down of the system? I do have TechStream V9.3.002, but have never done a ABS accumulator replacement on a Prius.
    Patrick, if you could chime in, or other Prius gurus and offer your expert opinion, it would be greatly appreciated :)
  2. PapaWill
    PapaWill Member
    137
    25
    Maui, Hawaii
    Any luck Jerry G?
