ABS failure
Discussion in 'Gen 2 Prius Main Forum' started by jamarimutt, Aug 22, 2006.
  1. jamarimutt
    jamarimutt New Member
    985
    Yesterday an awful sound came out of my 2004 Prius' front right wheel area. It sounded like a worn brake pad contacting the disk. The sound disappeared in a second or so, and about 20 miles later the red brake light, the yellow ABS light and an exclamation sign inside a circle came on. Given my location at e time, taking the car immediately to the Toyota dealer was out of the question. Besides, the car continued to brake normally. Today I made a test on wet pavement and confirmed that the ABS system is not working. The car has 45,000 miles on the odometer, so this repair won't be covered by the warranty
    I wansn't expecting this from a Toyota. <_<
  2. Tideland Prius
    16,075
    That's odd.
    Hmm, is that out of the powertrain warranty?
  3. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(Tideland Prius @ Aug 22 2006, 07:32 PM) [snapback]307887[/snapback]</div>
    It's probably not, as brakes aren't technically part of the powertrain.
    And I know that the regenerative braking doesn't really use the brakes, but hell... try to approach it from that angle and get them to at least reduce the cost somewhat.
  4. RichBoy
    RichBoy New Member
    189
    you should take it to your Authorized Toyota Dealer at once.
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    At 6092 miles my ABS and Brake lights came on. Fortunately I forgot what I read in the manual and drove the car to the dealer with normal brake function. They replaced the ABS actuator and resistor but did not reconnect the dimmer switch. (It took another day to reconnect the switch.)
  6. c4
    c4 Active Member
    607
    51
    I had a wierd case last year where a brake light bulb burned out, but instead of an open circuit like the usual case, it shorted, and this actually caused the ABS light to turn on and the car defaulted to mechanical brakes only (no ABS, no regen during braking), so check your brake lights, including the high-mounted light (which was where I had the bad bulb)..
  7. gasmiser
    gasmiser New Member
    Phoenix,az
    We have a 2008 Prius and ABS lights and warning came on and went to have it checked at a mechanic shop and they said the programming had been erased.nobody has a scanner here and the car had it come on once before but no codes,now this anyone else had a ABS software glitch?
  8. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    In the worst case if it was actually the ABS pump, it will cost you $$$.
    I replaced the ABS pump on my old Honda (yes, it happens to Toyota/Honda also, don't doubt it.) Unless it is a short, whenever there is a light, there was a code thrown.
    My dealer wanted $2500 (inc. labor) with new parts. Eventually I got it down to $1800 for a refurbished part.
    Later on, I found it on BMW forum that there are people who could refurbish the module for you (send them the ABS module, they will send it back once it is done) for about $300-500. You then have someone install it at your preferred shop (labor cost is not that high actually. It is the part that is costly.).
    Anyway, just FYI. Search the web for such people if you want to take a bit risk and save money. If you need to, go to roadfly.com (originally a BMW-only forum), and ask guys over there. I haven't been there for a long time since I sold my probemetic BMW.
  9. Patrick Wong
    18,200
    6,464
    What is a "mechanic shop"? Suggest you visit your local Toyota dealer for a diagnosis since the braking system is quite special and it is unlikely that a non-Prius specialist will be successful diagnosing its problems.
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    only when my ignition coil was failing. i would get abs lights in long left hand turns.. not sure why.. but after replacing the coil (since the problem eventually got worse and started to shudder) the problem went away.
