ABS issue, Beeping and many dash lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sarah Brady, Aug 17, 2023.
  1. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    I also think that you have multiple issues with your car. The first thing you need to do is buy a better scantool that can communicate with all the ECUs in your car. Take a look at the link below, which reviews a number of different scantools for a Gen 2 Prius.https://priuschat.com/index.php?threads/232741/
  2. ChapmanF
    19,056
    As far as the codes from the brake system, that system has a way to get the codes without a scantool, and she did that.
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    Now if she did have a better scantool, she might also get the INF codes that go with her C1241, and it might be helpful to have those, as dolj suggested in #10.
    Also, the better scantool would get the code(s) responsible for the red triangle light, which would be worthwhile to have.
  3. theory816
    theory816 Member
    112
    23
    What do you think about the mini VCI techstream? When I used it a while ago, it seemed pretty accurate.
  4. Brian1954
    2,694
    1,077
    TechStream is what Toyota dealerships use for diagnostics, so it is the gold standard.
  5. Sarah Brady
    Sarah Brady Junior Member
    Mississippi
    Hey Y'all. I have returned with an update. I changed the 12V battery to a new one and replaced the inverter coolant pump. As of right now, I have no more warning lights. The coolant reservoir is turbulent like it is supposed to and everything is normal. I did end up bleeding the inverter just to be safe (I dropped a clamp :rolleyes:). I will be driving it around later, Here's hoping the lights stay off!
    dolj and bisco like this.
  6. ChapmanF
    19,056
  7. theory816
    theory816 Member
    112
    23
    Is the old pump bad and how did you test for it?
  8. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Now that you have your car running I suggest you get the following items for “next time”:
    a Mighty Max 35Ah 12 v battery from Amazon. Much cheaper than any other 12 v bat and pretty easy to install - terminal clamp bolts thru the battery post holes, and some wedges to hold it in place
    a cheap smart charger - Foxsur from Amazon
    keep the spare battery charged with this
    Mini VCI Techstream from eBay. It’s hacked so it never expires. Of course don’t try to log on to the Toyota Techstream website
    get the components and build a grid charger. This will enable you to charge your HV bat if you have an issue with repeatedly failing to get the engine running. Cost will be under $100
    This way you’ll have a few things you might need next time a problem crops up
    congrats on changing the coolant pump. If you can do this, the above items are easy. Just be very careful around electricity
  9. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    You don't really need to be buying a battery now for something that might happen 2-5 years in the future.
  10. Sarah Brady
    Mississippi
    I don’t know how the pump wasn’t “bad.” The only test I did was on an OB2 scanner that indicated the inverter pump. As well as looking at the coolant reservoir for turbulence. After I replaced the inverter pump and bled the coolant the red triangle was gone and the coolant reservoir was turbulent as it should be.
  11. Sarah Brady
    Mississippi
    Updating once again. While driving the check engine light came on and is staying on. sigh. I looked at the blink codes and am still getting the same results as before (post #2). I am reading through your suggestions again and believe I will need to check the list in post #10. How will I know a relay is bad?
  12. dolj
    dolj Senior Member
    8,655
    4,406
    The ABS NO. 1 & ABS NO. 2 relays are located in the engine room fuse box. They are the green rectangular ones, one at the top, and the other at the bottom right.
    Here is a link that will show you how to test a relay.
    How To Test An Automotive Relay At Home | Mechanic Base
    It might be time to find a way to read the HV system codes you're not seeing just so you can get the full picture. A few posts in this thread have already mentioned the scanner review thread which contains a few options.
    Sarah Brady likes this.
  13. Sarah Brady
    Mississippi
    Hey y’all. At the end of my night my dash shut off. I can’t catch a break with my Prius I swear. After reading other threads the instrument cluster is needing replacement now. I guess it’s time to open up the dash. Thanks for everyone’s help. I think I’ve decided to replace the cluster, I am not knowledgeable enough to try to replace the caps etc. I am wondering if that’s why the check engine light came on? Because everyone I’ve seen with the dash off will still occasionally show the check engine.
    Also, for those recommending better code readers, thank you for sharing those options. I will look into purchasing after the next replacement.
