ABS light a constant flash - 2001 model
Discussion in 'Generation 1 Prius Discussion' started by TexomaEV, Jan 9, 2013.
  1. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    Recently, (luckily after the kiddo took her driving test) the ABS light constantly flashes at a steady non- patterned flash. Other than it just continues to flash, nothing seems to be out of the ordinary. Once in awhile it will not flash from a restart, but lately it's flashing more than not when restarted. Any ideas? I had hoped it would flash a certain pattern in order to help you to troubleshoot the error.
  2. ChapmanF
    18,503
    Not sure what it means with a regular flash outside of test mode. (It's probably in the manual, but my manual's not with me.)
    On the other hand, in test mode it will give you a patterned flash that you can read as two-digit codes (e.g. blink blink ... blink blink blink would be 23). Multiple two-digit codes will be output with longer pauses between the codes. You know you've seen them all when it cycles back to the first one you wrote down.
    You can get it into test mode by putting a jumper wire between TC and CG (pins 13 and 4) at the diagnostic connector, and turning the ignition ON.
    The manual shows the correspondence between these two-digit codes and the five-character codes used as OBD-II trouble codes, and also what they mean. You can post the codes here once you have them.
    -Chap
    scotman27 and TexomaEV like this.
