ABS Light is still on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Franky Southside, Jun 26, 2020.
Tags:
  1. Franky Southside
    Franky Southside New Member
    massachusetts
    I have a 2009 Prius that lost its brakes a few days ago. I had a mechanic come down and he said the back cylinder had broke. Both back brake systems were replaced and there was no fluid leakage. The brakes were bled until there was no more air in the lines. But the abs light and brake light is still on and I still have no back brakes. Anyone know what this could be??
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    Many use a hybrid compatible OBD2 scanning device, the best being a "mini-vci" cable with Techstream (dealer level tech software).
    You can also buy a OBD2 bluetooth/wifi adapter and an App like Dr. Prius or Hybrid Assistant.
    Here is a link to help you pick out a usable OBD2 adapter : Hybrid battery diagnostic and repair tool for Toyota and Lexus
  3. ChapmanF
    15,603
    If you don't already have such an animal, just reading the blink codes from the brake computer can be an option. It doesn't give you as much information, but in a situation like this, it may get you a code that indicates some simple step that's been overlooked.
