ABS Module part number?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SB6, Jul 29, 2019.
  1. SB6
    SB6 Member
    314
    69
    Does anyone know what the part number is for the "ABS module"? My traction control, ABS, and 2 brake lights turned on, as well as loss of regenerative braking. Code C1345 Linear Solenoid Valve Offset Learning Undone. Learning procedure fails. Went to the dealership, they said I'm not covered under the brake booster customer support program. 2 local mechanics said I need to replace the ABS module, another said master cylinder. I'm looking for the ABS module online, but not sure what the part number is
  2. ChapmanF
    15,560
    Gen 3 ABS ECU is-integrated-with the brake actuator is-integrated-with the master cylinder, so pretty much all your answers were right. Try 47050-47140.
    If I remember right, these used to be quite a bit saltier. Maybe I'm imagining it.
    SB6 likes this.
  3. SB6
    SB6 Member
    314
    69
    :LOL: What?
    Okay, I'm confused. When I look up 47050-47140 on eBay, the results are all nearly $600. However, when I lookup "2010 Prius brake booster" or "2010 Prius master cylinder" etc, I see similar looking parts from around $150 (used), but with different part numbers. For example, there's this listing for $160, but the part number is 47210-47140. What's the difference between these?
    #3 SB6, Jul 30, 2019
    49,431
    pretzels?
  5. SB6
    SB6 Member
    314
    69
    I'm not sure what you guys are talking about, but a pretzel shape could definitely be used to describe my confusion :LOL:
    Raytheeagle and bisco like this.
  6. bisco
    49,431
    i'm not either :whistle:
  7. ChapmanF
    15,560
    Well, so it's like this. There was an old unit, catalog number 47050-47060. Toyota doesn't sell that one anymore. It's been superseded by 47050-47140.
    The old part, with the catalog number 47050-47060, also had a "mark", 47210-47140 (see the bottom of that pasted image). I've never completely understood why car parts often have a number marked on the part that looks just like a catalog number but is different. I first ran into that with Ford. Walk in with a piece in my hand and say "see, this number right here" and the poor guy at the counter would have to try to look it up 'cause that wasn't the part number.
    Unsurprisingly, when recyclers pull used parts out of cars and list them on the web, they will often be reading the "mark" off the part, instead of finding the right part number.
    The newer, superseding part, 47050-47140, also has a "mark", 47210-47310.
    I was surprised to see Toyota listing the thing for $710 dealer suggested list, because it wasn't long ago PriusChat was filled with posts about how it was $1600–$1700, or $2500, or $3500 Canadian.
    I notice lots of internet sellers throw the word "pump" into the description of this part. Don't be fooled; in Gen 3, the pump and accumulator are in a separate assembly, not part of this one.
    Robert Holt and SB6 like this.
  8. Elektroingenieur
    2,515
    3,258
    Three Touring
    Toyota’s production and service part numbers use the same format, so I expect it’s a production part number for one of the components of the assembly, or for the assembly without the ECU firmware.
    I agree with Frank Watts, author of Engineering Documentation Control Handbook (see “Item Marking,” 4th ed., p. 69): marking any number on parts is wasteful and leads to just this kind of confusion.
  9. SB6
    SB6 Member
    314
    69
    Thank you! That makes a lot more sense. Would I be okay using the old part (47050-47060), or would I be worse off for it?
    Also, if I use the old one and it fails on me, like the ones being replaced under customer support program ZJB, will Toyota cover it? Is that how it works? Or will they refuse due to it not being the original part on my car, or due to the previous replacement being done at a non-dealership shop?
    One more thing. Since I've only been told to replace the ABS module/master cylinder, can I just replace the 47050-47140 part, or do I need to replace the pump assembly as well?
    #9 SB6, Jul 31, 2019
  10. ChapmanF
    15,560
    Hard to say. I would assume they updated the part for a reason, but I have no inside information.
    I'm thinking that might be regarded as a stretch....
    They're both somewhat expensive and somewhat exhausting to replace, so any time I could find a way to pinpoint which one was the source of a problem I was having, I would probably not rush to change the other one just because.
    Depends, of course, on how confident you are in the pinpointing.
    SB6 likes this.
  11. SB6
    SB6 Member
    314
    69
    So... I have been thinking about whether I should get the newer version or stick with the older version, and apparently I've reached a compromise :LOL:. I ordered a part listed as 47210-47310 for $200. So if it's correct, that's the "mark" number for the newer part, and so I'll get the newer part. If not, then... :shrug:
    Thanks for all the help, ChapmanF!
    Now hopefully the repair goes smoothly...
  12. ChapmanF
    15,560
    Looking at how the price has come down, I'm seriously thinking that if I ever turn out to need one, I might just buy new, and avoid wondering about whether a used one has an exciting past, or about what kind of trained primate performed its removal from the donor car. (Toyota has TSBs giving very stringent handling instructions, including no cloth/fabric gloves or rags, anything that could shed tiny textile fibers that could get into the valves. As far as salvage-yard disassembly operations following those instructions, I have a level of confidence somewhere near zero.)
    PriFi and Robert Holt like this.
  13. SB6
    SB6 Member
    314
    69
    While I completely agree with you, I'm just not really financially established yet. So although I could've afforded a brand new part, I need to save where I can. The part I bought was listed as being in "excellent" condition and also has a 90 warranty, so here's hoping...
  14. ChapmanF
    15,560
    I understand.
    Under the circumstances, the best you can do is to make sure you follow the handling instructions as carefully as possible while unpacking and installing it.
  15. SB6
    SB6 Member
    314
    69
    I was actually planning on having it installed by a local shop. I haven't yet looked up the process for doing it myself, but is it something a layman can do on their own? All I've ever done is stuff like oil change, changing a tire, wiper blades, headlights, and replacing small interior things
  16. ChapmanF
    15,560
    Compared to those things it's considerably more of a job, and with safety implications. Going to a shop is probably the right call, if you trust the shop.
  17. SB6
    SB6 Member
    314
    69
    So I got the repair done yesterday, and drove about 400 miles between cities today. About 300 miles in, my brake warning light started flashing and then a while later turned solid, and I would occasionally catch a whiff of a burning smell.
    Pulled over and checked around the car. Everything seemed okay under the hood, although I saw some drops of liquid splattered around the passenger side. I checked my tires, and noticed this thing hanging. It was occasionally touching the tire and causing the burning smell. I decided to pull it out. Got back in the car and the light went away after a while, but then came back later on. Flashed again for a while, then went solid again. Currently in another city. Anyone know what this means?
    #17 SB6, Aug 14, 2019
  18. ChapmanF
    15,560
    The thing looks like some bit of the plastic under covers; you'll probably be able to figure out which bit at your leisure by looking at the parts diagrams, or at the other side of the car for comparison.
    Of more concern is the dash light. What are the trouble codes?
  19. SB6
    SB6 Member
    314
    69
    The dash light was actually the TPMS light, not the brake system light. I wasn't able to get it scanned while it was on, and I haven't seen it back on in the past couple weeks. I'm not too sure what it was, but hopefully I'll be alright now
  20. dulguun gereltuya
    dulguun gereltuya Junior Member
    denver
    HEY MAN HOW DID IT GO DID YOU INSTALL IT BY YOURSELF? DOES IT NEED REPROGRAMMING AFTERWARDS? I NEED HELP I BUYING USED PART WHAT WAS THE PART NUMBER U BOUGHT AND WHAT WAS YOUR OWN PART NUMBER
