ABS Part question
Discussion in 'Gen 2 Prius Technical Discussion' started by Eunhon, Aug 22, 2019.
  1. Eunhon
    Eunhon Junior Member
    Hello, I currently have a 2nd gen Prius that had the typical abs pump failure . part number is 44500-47140 . my qurstion is would i be able to put part number 44500-47141 in it? I'm not sure if its interchangable. I appreciate any help!
  2. MilkyWay
    MilkyWay Active Member
    819
    357
    23
    MI
    That is the upgraded version (typically out of a 2009)...Yes, that is the good one. Can also shop on car-part.com if you want to save $100s of dollars and don't mind used....
