Abs problem ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fsh4bass, Nov 19, 2025.
Tags:
  1. Fsh4bass
    Fsh4bass New Member
    I have a 2005 with 195,000 miles
    recently had the red brake light, ABS, VSC and (!) come on. Codes C1257,C1300 and C1391 are present. I cleared codes drove 70 miles and they did not come back on. What should be my next move ?
  2. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Nothing, presuming the car runs fine at the moment.
    In the meantime, I would find a copy of the repair manual, or look into getting a 2 subscription to Toyota TIS, so you can look up any codes you might find in the future.
    If the dash lights up again, read the codes and see what you have then.
    BTW, C1257 does not appear to be a valid 2005 Prius code. What scanner gave you that code?
  3. Tombukt2
    Tombukt2 Senior Member
    13,847
    2,515
    Durham NC
    C1257 system cannot run pump.
  4. Fsh4bass
    Fsh4bass New Member
    Sorry that was a typo it’s C1256
  5. dolj
    dolj Senior Member
    8,640
    4,391
    Getting the INF code for that DTC would help with the diagnosis. A full-featured code reader that can access the freeze frame data is what you need to do that.
