ABS pump making noise
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by PriusHead05, Oct 26, 2020.
  1. TheDefiant
    TheDefiant New Member
    192k miles. Lights came on the dash. ABS, brake light and traction control
  2. TheDefiant
    My messages are not going through since they are awaiting a moderator. In any case, my warning lights came on. The ABS, brake, and traction control. The car feels sluggish now and the brakes are harder to actuate but it is still driveable.
  3. ChapmanF
    18,725
    Because it is past 150,000, I think it is past coverage under the ZJB warranty extension.
    You might want to see what an independent shop would charge for the repair.
    Some people might look for used parts, though a used part might be near the same condition, and the labor of replacement isn't something you'd choose to pay for twice.
  4. Tim Jones
    Tim Jones Senior Member
    1,760
    565
    SE Texas
    2011 Nissan LEAF
    Go to the dealership with the vin number..........they replaced mine with over 260,000 miles
    Can you drive it there?
    Agree to diagnostic fee THAT IS $0 IF IT'S THE CORRECT CODES.
    I'm pretty sure your good to go.......
    #24 Tim Jones, Oct 19, 2021
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,688
    6,714
    Texas Hill Country
    The v wagon is unlimited miles until Dec 31st. The hatchback unlimited mile expired Aug 31. Both will continue to have 10 year/150,000 coverage based on original purchase date.
    #25 rjparker, Oct 19, 2021
    Tim Jones likes this.
  6. rjparker
    10,688
    6,714
    Texas Hill Country
    Attached is the coverage letter for hatchbacks. 0B29591B-EB48-41DF-B7AF-B2AC40FA4F40.jpeg
    #26 rjparker, Oct 19, 2021
  7. TheDefiant
    Of course that would just be my luck. The pruis was in the shop for a long time for the head gasket replacement. Only to come home to this problem. Had it happened before the head gasket was taken in to get replaced. It would have been before Aug. I wonder if Toyota can make an exception based on certain circumstances? If not, then I guess I will try to do this on my own.
  8. Tim Jones
    1,760
    565
    SE Texas
    2011 Nissan LEAF
    Do you have a v or a hatchback?
    v your good to go.
    This is the v forum.
  9. TheDefiant
    I'm an idiot. Lol. I have the hatchback.
  10. Tim Jones
    1,760
    565
    SE Texas
    2011 Nissan LEAF
    Thank toy for another blunder..........gen 3 total nightmare when they get some miles on them...
    Next will be the traction battery.
    Has the inverter blown yet?
    The brake fiasco will set you back up to $2500 installed at toy. I put a used one in my car and it went out but luckily the junk went out and I had the correct codes....
    Hope it works out........prius.......gets good mpg but that's about it...............
  11. TheDefiant
    The funny thing is, I got this vehicle to use as the commuter and to teach my son to drive and then eventually having it become his first car. I had high expectations for it. And I went with the toyota so I don't have to deal with issues exactly like this. If it isn't covered, I will attempt to do it myself. I just finished spending upwards of $1k on the head gasket and EGR. Anything else that comes up after this and I will either sell it or burn it.
  12. Tim Jones
    1,760
    565
    SE Texas
    2011 Nissan LEAF
    You will need a new traction battery sooner than later. $1600.....
  13. rjparker
    10,688
    6,714
    Texas Hill Country
    You should try calling Toyota corporate. If not successful, consider fixing it one way or the other. To bleed an empty master cylinder is not diy unless you have Techstream or one of the more expensive Pro scanners. The two assembly brake booster system is quite a job, about six hours by the book for a pro.
    Used parts are a gamble because of the labor and can be the wrong part. Many Prius versions look the same, but they include a brake ecu which has revisions by year and tire size. Most used suppliers don't know this and may send you the wrong part. You want to verify your part numbers by vin and then verify their part by the vin it came from.
    You could buy new parts online, install and then get a dealer to calibrate and flush the master cylinder. That is the better solution, especially if you intend to keep it.
    There was a class action suit but I believe Toyota "settled" by agreeing to the expanded warranty that was already in place.
    If you could find a good non hybrid to replace the Prius, I would get the Prius running and then sell it, especially if it burns oil or has the original high voltage battery. As Tim suggests, the gen3 Prii are very expensive to own after 150k miles. A 2016 or newer hatchback is reengineered to resolve these issues except for a battery around 175k - 200k. An older Rav4 is a pretty safe bet.
    #33 rjparker, Oct 20, 2021
  14. Tim Jones
    1,760
    565
    SE Texas
    2011 Nissan LEAF
    I think the brakes parts only are $1200........might be more....
    To keep
    AC works Good
    Water Pump..... not hard
    Inverter water pump...... I've done it.....
    Change Trani fluid....easy
    Inverter updates current
    And at any moment... Traction Battery
    And the engine doesn't use any oil or just a very small amount every 4 to 5000 miles
  15. TheDefiant
    Ok, got the entire brake system repaired at Toyota. They actually got it covered under phase 2. Based on the TSB, I didn't qualify due to mileage, but they covered it so I am thankful. And just to add insult to injury, the next day after getting it back and on our way to work, the engine blew (threw a rod). So now I need to find an engine and swap that out. Yay me. But thank you all for your help with the ABS stuff.
