ABS pump replacement - now, won't start?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kevin Lester, Nov 4, 2023.
  1. Kevin Lester
    Kevin Lester Junior Member
    35
    Good tip! I've got the Noco Genius 5 ready for when I start the bleed - is 5A enough of a charge?
  2. Kevin Lester
    35
    Alright! Bled the lines at each wheel - let them run a bit extra to purge the old fluid, and kept the reservoir topped off. Started the car, no codes. Drove it around the block a few times. Times brakes work great, no codes popping up yet. I'll drive it tentatively a bit later, just to make sure that the hybrid battery system etc. isn't showing signs of trouble.
    But, I'm feeling pretty good about this.
    #22 Kevin Lester, Nov 6, 2023
  3. Kevin Lester
    35
    Awesome - it seems to be driving just fine. I'll keep a close watch on it over the next couple weeks.
    In the meantime - onward to the belt and the water pump! (then, fluids, filters, washer pumps....) :)
    Thank you all so much! If you ever make it to Tucson, beers on me.
    JohnPrius3005 likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Kevin,
    Did you use the Autel AP200? If so, did you like the format it used? I've been thinking about buying one also, to go along with my techstream.
