ABS Relay 1 problem - brake accu?
Discussion in 'Gen 2 Prius Technical Discussion' started by Michciu94, Sep 17, 2022.
  1. Michciu94
    Michciu94 Junior Member
    45
    Poland
    My English is not perfect. So you said it is pretty normal ?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Yes. That is normal.
    My 2006 turns pump on around 3.2V and off around 3.6V. I get 2-3 pumps on brake pedal before pump turns on again. If I don't use brakes, voltage goes down 0.02V in 30 minutes.
  3. Michciu94
    45
    Poland
    Mine also same so the repair is fully successful. Thanks ;)
