abs/trac/brake light on after 12v battery replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ritesh patel, Oct 20, 2023.
  1. ritesh patel
    ritesh patel New Member
    can some one help i just changed 12v battery on prius two 2014 now the trac/abs/brake light on mechanic try to scan and recalibrte abs but still now any idea how to fix the lights
  2. Tombukt2
    Tombukt2 Senior Member
    13,821
    2,507
    Durham NC
    So does the new 12 volt check out to be good batteries come off the rack bad all the time. If in fact the 12 volt is good disconnect it for 5 minutes completely reconnected properly positive first ground last no sparking put the negative terminal on the battery with purpose Don't make a lot of sparks and noises. Now what's happening?
  3. Bill Norton
    Bill Norton Senior Member
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    This is true.
    Lead Acid batteries have 'Self-Discharge and if it has been sitting on a shelf, untouched for a long time, it can be damaged from being in the discharged state for so long.
    Batteries should have that round 'Date of Manufacture' code. I always check that before buying one. And I always trickle charge a brand new battery to top it up before installation. Aviation batteries call for that.
    (btw, nice use of Punctuation and Capital Letters for part of your post. It was somewhat readable!!(y) )
  4. Mr. F
    Mr. F Active Member
    389
    264
    Washington
    If those lights are on, there will be stored codes. Read them off with a capable scantool (or even just a paper clip) and post them here so members can help.
    Brian1954 likes this.
  5. ASRDogman
    ASRDogman Senior Member
    8,050
    4,082
    Did you charge the battery before installing it?
    You should put a 4amp or less charger on it for 8-12 hours to give it a FULL charge.
    Bill Norton likes this.
  6. ASRDogman
    8,050
    4,082
