abs, vsc and brake light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AngelK, Aug 22, 2019.
  1. AngelK
    AngelK Junior Member
    17
    Clarksville, TN
    All 3 came at the same time. I had just started the car and driven a little down the street. Pulled over, scanned it with an obd and no codes, restarted the car and lights went away. Havent come back since, been about 10 miles. When i recently had the car inspected mechanic told me to have rear brakes cleaned and adjusted which i planned on doing soon. Would that have something to do with it and what should be my next plan of action?
    PriusPaddler likes this.
  2. ChapmanF
    19,058
    What OBD scanner did you use?
    I might toss a short piece of wire in the car just to have on hand in case the lights come back, to at least jumper the Tc annd CG terminals and count the light blinks, if the OBD scanner isn't showing the codes.
    PriusPaddler, SFO and Skibob like this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I think you already know the answer to this. ;)
  4. jonwilhelmjr
    jonwilhelmjr Junior Member
    US
    I have found my passenger rear wheel speed sensor terminals are corroded. Now I have not verified this as the fix because my wheel bearings are shot. I'll update as I know more. I have the same lights that go on and off.
    SM-N950U ?
  5. caravan2429
    caravan2429 Junior Member
    64
    Sandy, UT
    Bad ABS sensor wires. Check connection and wire itself.
  6. AngelK
    17
    Clarksville, TN
    Codes that came up are u0123, u0124, and u0126. Is it ok to drive with these for awhile?
  7. AngelK
    17
    Clarksville, TN
    Codes i got are u0123, u0124, and u0126
  8. Patrick Wong
    18,214
    6,530
    Those three codes indicate there is a problem with the steering sensor and yaw rate sensor. Maybe there is a problem with the wiring to those sensors.
    Do not expect a regular mechanic (who does not specialize in Toyota hybrids) to be able to resolve the problem.
    Is it OK to drive with those: well, your braking system is impaired. If you don't drive in a manner that requires emergency braking you might be OK. Or you might not be OK.
    PriusPaddler, SFO and blaisep like this.
