ABS ,VSC , BREAK RED LIGHT INDICATOR
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vanne, Apr 17, 2016.
  1. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    Hi everyone
    Could you please advised me how to fix this error as in attached image it show me after I change 4 tire a few days ago
    Thank you for help
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Looks like one or all of the tire tpms sensors failed or didn't make it to the new tires. The battery's in the tpms only last 9-11 years.
    The batteries are not serviceable they come built into the sensor.
    New tpms sensors can be found on amazon.com there denso's. New sensors require Techstream software to register them with the car.
    There's a few tpms youtubes.
    And the ABS-VSC nag is usually caused by one or more abs speed sensors damaged or mis-aligned. There's one at each wheel. You need Techstream software to find which wheel is complaining.
  3. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Get miniVCI from Amazon/ebay ($25-$30).
    A laptop is required for installation. Ideally a spare Windows 32 bit Operating System (XP, Vista, 7). Many threads on installation help (Win 32bit, Win 64bit, Mac), just search the Internet.
    Once you have both (miniCVI and a laptop), you can get the codes and proceede from there.
  4. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Oh and I forgot. If you have different size tires around the car it will put the ABS and VSC out of whack.
