ABS warning after skidding in snow
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mel08, Feb 13, 2014.
  1. mel08
    mel08 Junior Member
    Boston
    Today while trying to get in my driveway I skidded in some snow and was temporarily stuck. After shoveling the snow and getting in the driveway I stopped the car and restarted it. I now have a warning buzzer and ABS warning lights on. Any way to get these reset without having to take it into the shop in the morning?
    This same thing has happened before and cost a lot of money for them to say everything was fine and reset the warning light.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Perhaps the light will go off after 5 or 6 restarts. Some warning light behave that way.
  3. Patrick Wong
    18,210
    6,515
    Do a search for how to clear skid control ECU DTC, by using a jumper on pins 4 and 13 of the OBD-II connector.
  4. mel08
    mel08 Junior Member
    Boston
    I tried restarting many times and drove the car ~2 miles and I tried the obi-ii reset with no luck. Any other options?
  5. Patrick Wong
    18,210
    6,515
    There actually might be something wrong with the skid control ECU or a wheel sensor.
  6. xpcman
    1,302
    295
    Right. You may have damaged the wire(s) for a wheel sensor. It's best to have the dealer check it. At this point your ABS might not work correctly.
  7. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    FYI
    I among others (pc chat forum members)have now read about the large recall TOYOTA hybrids for VSC/ABS aka vehicle stability control/anti brake skid......
    The automotive mfg mass produce vehicles (therein mass produce recalls) Honda got sued by honda hybrid owning attorney who claim that Honda made false claims about MPG (gee what a surpise in a litigious society we have)Honda was able to get the case dramatically reduced.
    Anyhow I am not surprised about the VSC/ABS issues. Toyota did not do their homework. I can say from personal experience that the Gen 2 prius VSC/ABS is pathetic in wet/rainy/ice road condition. I think there is a pc chat member in michigan that has posted his issues also. The software for the VSC and ABS is truly lacking in certain weather/road condition. I wish and my desire is to maybe disable the DASHBOARD mfg made idiot warning lights for VSC/ABS
  8. xpcman
    1,302
    295
    The poster probably has physical damage to the car caused by sliding into a snow bank. Nothing to do with "homework" and lawyers.
  9. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    You can read the "blink codes" from the ABS system. For example:
    Skid sensor alarm, can't accelerate | PriusChat
    Report back what you find. This is something that will take just a few minutes. If there is an issue with the speed sensors, then it will show up in the blink code for each wheel.
  10. NortTexSalv04Prius
    915
    116
    nice guess but incorrect
  11. NortTexSalv04Prius
    915
    116
    product research and software develops aka homework people do have a direct responsibility for the ABS/VSC debacle now unfolding for Toyota.
