1. almog didi
    almog didi Junior Member
    israel
    Hello :)
    I have a 2014 Toyota Prius with 480,000 kilometers, and I've started having an issue where the ABS, handbrake, and VSC lights. The vehicle also beeps, and the brakes are very hard to press. I experienced a similar issue before, but without the beeping, and the brakes were fine. That problem was resolved when I replaced the angle sensor and spring clock.
    Now, I’m wondering if you have any suggestions on what to check before I replace the master brake cylinder. The part number I need is 47210-47480. Also, is it possible to use a part that only has the first five digits matching? (47210)
    ty
    52,742
    did you make 480k without ever having to read a trouble code?
  3. almog didi
    israel
    what do you mean?
  4. ChapmanF
    18,923
    If it's like the US models, you can read the brake trouble codes this way, if you do not have a scan tool to use.
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    The first five digits, like 47210-, are the "PNC" in Toyota-speak and only identify what kind of part it is. So PNC 47210 might be a master cylinder / booster, but they could have a ton of those for different vehicles, all being different in the last five digits. So, in answer to the question, no, you can't just match the first five.
  5. Brian1954
    Brian1954 Senior Member
    2,645
    1,055
    South Central PA, USA
    What are the trouble codes that are reported by your scan tool?
  6. almog didi
    israel
    I don’t remember the codes, and the car isn’t nearby now. The trouble seems to come and go. it's can disappears after I drive, but then returns the next day. If I reset from the OBD, the issue goes away, but it comes back after a day.
    My question is that the problem could be not the master brake?
  7. ChapmanF
    18,923
    Next time the car is nearby again and the lights come on, you can find out what the trouble codes are, and post them here.
    Brian1954 likes this.
