AC #2 Damper Servo replacement
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Lando Raymonds, Mar 24, 2026.
  1. Lando Raymonds
    Lando Raymonds New Member
    2018 Prius Prime
    The dealership wants $4,000 to replace this part, claiming they need remove the dashboard and drop the engine to get to it. I've read that it's possible to replace it DYI, but haven't actually seen any guides. Can anyone help me out?
  2. ChapmanF
    19,020
    I've never looked this procedure up for a gen 4. Remove the dash I believe; drop the engine I wouldn't believe unless I read it in the repair manual myself....
    Toyota Service Information and Where To Find It | PriusChat
    I could imagine them saying the whole HVAC unit under the dash might have to come out for access to that servo, which would mean disconnecting coolant and refrigerant lines behind the engine (and then refilling and recharging after the repair). If they've really made things so tight in the engine bay that the engine needs to be moved for that access, well, yuck.
    #2 ChapmanF, Mar 25, 2026
    amos and Lando Raymonds like this.
