AC blows hot air only when engine starts
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by fsab888, Jan 26, 2019.
  1. Sonic_TH
    Sonic_TH Active Member
    574
    96
    Puerto Rico
    2016 Prius c
    You disconnect the negative terminal of the 12v battery that is in the rear seats, leave it like that for a few minutes and the problem will solve, that's what i do with mine.
  2. Sonic_TH
    574
    96
    Puerto Rico
    2016 Prius c
    Still having the same issue to this day. Used heat, then moved the knob back to cold, but only hot air came out, so i had to disconnect the 12v battery.
