AC button not turning on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Juwan, Dec 16, 2020.
  1. Juwan
    Juwan Junior Member
    Hawaii
    AC issue only started to happen recently after my 12v battery disconnected. My fan blows fine and will turn on when I hit auto but no cold air and the AC light will not turn on. However, when I turn on the defrosters they will blow cold air with no problems. All the other lights on the dash work properly and my buttons don't seem to be sticky as some people I've seen on other forums had issues with. I assume it is possible that my AC button just doesn't work for whatever reason. If my air conditioner blows cold. I did some digging and the only forum that had similar issue was resolved by sticky off button but my off button works fine to cut off the fan. I'm hoping it's a simple fix. Thanks in advance! This is my first post but I've used Priuschat forums a lot over the past 6 months or so of owning my car including replacing the HV battery.
  2. Juwan
    Juwan Junior Member
    Hawaii
    I don't know if this helps but I live in Hawaii and usually have my AC on at low speed and haven't ever used heat. I don't know anything about fuses but I'm willing to give it a go if I feel like I can do it. Worst comes to worst I will take it into a mechanic and have him diagnose it in a week or so as its winter and it's not as hot.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,003
    6,894
    Texas Hill Country
    If you are sure its cooling in defrost it could be the control. Someone with a Toyota scanner may be able to monitor the status of the control. The ac compressor is high voltage three phase from the inverter. Don't expect just any ac shop to have good experience with this system.
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Check the 12v battery
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    You might want to try this HVAC chicken dance to rule out other contributors (such as a weak 12 V battery).
    The keystrokes for this test are start from ACC mode (power on without brake), hold down AUTO and Recirculate/Fresh Air buttons, and press START again. Should see A/C LCD and all LED lights blink 4 times at 1 second interval followed by a code displayed where the preset temperature (digits on left side of LCD) are normally displayed. A 00 code means no problems. Then press OFF to escape.
    If you see a code, you'll need the maintenance manual to decipher what it is. You should be able to locate that with a suitable thread search, or maybe someone else will chime in with an attachment.
  6. Garo Barsemian
    Garo Barsemian New Member
    Glendale
    Did you ever figure this one out? I’m having the same issue.
  7. ChapmanF
    18,957
    Agreed, if the A/C will work in defog mode, and the A/C green light works during the self test, and you can't make the green light turn on and off by pressing the A/C button (while the blower is on), then the button is a suspect and there aren't many others.
    seaglasspearl2013 likes this.
  8. Cortega315
    Cortega315 New Member
    Pawtucket, RI
    Did anyone figure this out? I just replaced my 12v battery and now my AC button won’t turn on anymore. The ac was working perfectly until the battery was replaced.
