AC button on key fob
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bluemanalbert, Jun 22, 2018.
  1. bluemanalbert
    bluemanalbert Junior Member
    40
    22
    visalia, CA
    Howdy,
    I'm not sure if other plug in Prius owners have the AC button on the key fob. I have the button, but I'm not sure how to get it to work or if the key fob came with it, but it was not part of the package. I'm not even sure how I would check if it came as part of the car. How can I check to see if I have the proper parts to make it work. Any help is appreciated.
    Albert
  2. jm64
    jm64 Junior Member
    25
    24
    Bay Area, CA
    2014 Prius Plug-in
    Do you have the manual? It's well documented, page 377 on the 2015 Manual I found online. I have a 2014 base model and it came with it, and works, so your 15 should as well. Basically you press and hold the button and assuming the car has battery power available, you'll hear it spool up and start the AC. I think it lasts for 10 min before automatically shutting off, or it will shut off when you open the door. It's also based on how you left the AC set when you last turned off the car.
    QuantumFireball likes this.
  3. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    I'm quite sure it will only run the A/C if the car is connected for charging. The precooling should then not deplete the traction battery's range.
    jerrymildred likes this.
    52,760
    all the plug ins have it.
  5. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    No, it will work unplugged, as long as the battery has enough charge.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Confirmed by a quick look in my OM.
  7. Bee Tee
    Bee Tee Junior Member
    39
    16
    Bay Area
    2014 Prius Plug-in
    Yes, and you must have The EV battery left, other wise, it will not turn on.
  8. bluemanalbert
    40
    22
    visalia, CA
    Something must be wrong with my car because I cannot get this to work. I have had a full battery and left my AC settings on when I turned the car off. I pushed the button. Held the button. Nothing. I unplugged and still had a full charge. Same, nothing.
  9. QuantumFireball
    420
    269
    Ireland
    This is not true, it will start as long as the SOC isn't very low (possibly 3 bars or less, not sure of exact threshold).
    Were you standing right next to the car? I don't think it works if you're within keyless entry range, if I recall correctly. If you press and hold the button on the remote it should initially flash, then flash again once you've held it long enough (0.7 seconds or whatever), and the indicators on the car should also flash.
  10. bluemanalbert
    40
    22
    visalia, CA
    I have tried it from keyless range and walking away from it. I tried it until the remote was no longer in range of the car. Held it down and waited for the light to blink. The car had been charging and battery was well above 50%. It was still charging when I tried it. I even unplugged it. Nothing works.
  11. QuantumFireball
    420
    269
    Ireland
    Maybe it's been disabled? It can be done at a dealer, or probably with Techstream.
  12. bluemanalbert
    40
    22
    visalia, CA
    Is there anyway I would be able to enable it without going into the dealer?
  13. bisco
    52,760
    someone else had this problem, but i think the car was salvage, have you owned yours since new?
  14. bluemanalbert
    40
    22
    visalia, CA
    I bought mine pre-owned.
  15. bisco
    52,760
    could be anything then, hard to say. if you have carefully followed the instructions and it doesn't work, you probably need tech stream for a deep dive.
  16. QuantumFireball
    420
    269
    Ireland
    The manual states in the "Customizable features" section that the remote A/C operation can be configured "by any authorized Toyota dealer or repairer, or another duly qualified and equipped professional" - I assume that means either some OBD-II stuff, or Techstream. I don't recall seeing specific OBD PIDs for this one (unlike the reverse beep thing).
  17. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    try locking the car before you turn on the AC
  18. bluemanalbert
    40
    22
    visalia, CA
    I was hoping it would be some simple PID thing I could do myself.
    be well
  19. bluemanalbert
    40
    22
    visalia, CA
    I've tried locking the car and unlocking. I've tried it at the car has been locked and charging for about an hour just to make sure there is enough charge.
    be well
  20. SteveMucc
    391
    268
    Kentucky
    hum... I turn mine on from inside the house almost every day without any problem. It might be time to hit up the dealer. Good luck
