AC button on key fob
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bluemanalbert, Jun 22, 2018.
  1. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    I stated "2020 manual" on post :D
  2. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    @jerrymildred primed m8 :whistle: My apologies OBD! My 2020 manual 3 weeks old. Thanks Jerry for the write up on the OBDII access! I was hoping to find a bluetooth that did not require a subscription. Holding out hope there's one out there but I do have a 32 bit computer!
    #42 Dael, Oct 16, 2019
    jerrymildred likes this.
    52,854
    fair enough, i missed that.
    can you know tell us what vehicle you are asking about? you have posted in the 2012-2015 plug in prius thread.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    That's the hot ticket right there. You can do anything the dealer can do that way. The bluetooth ones with phone app are nice, though, if you just want to do a quick check or customization, plus you can mount the phone on the dash and use it as a display for engine speed, coolant temperature and just about any other info you might want displayed as you drive. ... or you can just drive it, which is my usual recommendation.
    It's too bad there isn't an Android or iOS version of Techstream. :D
  5. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    @bisco yep sorry m8, gittin carried away here, I will slowly back out ;)
  6. bisco
    52,854
    thanks! what is an m8?
  7. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    Mate/m-eight
  8. Karl Goh
    Karl Goh Junior Member
    31
    New Zealand
    i-Tech
    bought mine pre-owned about 4 days ago. 2012 Jap import.
    Had to google translate the instructions on manual.. tried holding down the A/C button and it worked. left it there for 30mins or so while charging. came back and ready to drive, the A/C was already switched off. but car is not as hot under the sun so kinda a good thing.
    Dael likes this.
  9. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    You can download English language manuals from Toyota GB here: My Toyota | Toyota UK
    It is for the Europe/Aus/NZ model, so there will be some differences with the Japanese spec.
    The remote aircon will only stay on for about 10 minutes, and can turn off earlier is the set temperature is reached or battery SOC is low.
    jerrymildred and Karl Goh like this.
