AC compressor pressure relief valve
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by popptj2001, Jul 11, 2017.
  1. popptj2001
    popptj2001 Member
    79
    52
    What would cause the pressure relief valve on my AC compressor to be ejecting refrigerant? I have about 12 oz of refrigerant in the system (below capacity) and it blew. So I can't keep enough refrigerant in the system to keep cool. Blows out.
    Defective valve?? Restriction somewhere ??
    I have gauges and will check pressure as soon as I can, but wanted to see if anyone had similar issue, or recommendations.
  2. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    I hope your gauges are virgin and not used on a normal auto ac set. It would be contaminated with pag oil that is not compatible with the prius ac unit. Can't help you with the your primary issue, sorry.
  3. Flipzillatron
    Flipzillatron New Member
    Did you ever figure out what was causing this? I'm having the same issue on my wife's compressor.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    What exactly is "the same issue" that you are having? What work have you done or have had done to the car? What are the A/C system operating pressures?
