AC Compressor Question--After Wreck
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by popptj2001, Jun 9, 2016.
  1. ChapmanF
    18,889
    The compressor won't run unless the HVAC controller wants to run it. Why doesn't it want to? That's what the codes it has given you are probably trying to tell you.
    -Chap
  2. popptj2001
    popptj2001 Member
    79
    52
    PATRICK!!!!!! I am sitting in my nice cool cab with the windows up. Temp dropping as I add refrigerant. I retried your sequence of adding freon, disconnected the battery for 10 min, and restarted the system. Cold air! Thank you so much. You are my hero! Lol
    Toby
  3. Patrick Wong
    18,210
    6,517
    Excellent, congrats on your persistence and success!
  4. Jesus82
    Jesus82 Junior Member
    24
    63
    Denver co
    Hi I'm new to the forum and in need of help
    Same problem is yours 2006 prius a/c compresor when bad. I replaced with a salvage one (good one) vacuum the lines and compressor won't engage and it won't take the freon. what was your solution.? I see Patrick's instructions did this help you.? If so can you go in more detail thanks.
  5. popptj2001
    popptj2001 Member
    79
    52
    Vac system, disconnect from battery to clear codes (I did for 10 min but not necessary to clear that long I don't think), add freon with the car OFF. For me I added a 12 oz can for about 10 minutes before I started the car. Compressor engaged, cold air.....continued to add till can is empty.
    My system isn't completely full as full is around 15 OZ I believe, but I am getting 44-48 degrees at the vent. Works fantastic.......430,000 miles <bragging>.
    Patrick, please correct me if I missed something.
