AC doesn't work at high RPM
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, Jul 23, 2017.
  1. franken1313
    franken1313 Member
    216
    27
    US
    I have a 2005 prius & My ac stops working at high rpms. Can someone help me??
  2. JC91006
    16,933
    8,643
    Are there any warning lights? Ever had front end accident or fan replacement?
  3. franken1313
    franken1313 Member
    216
    27
    US
    No warning lights. Fan turns on & seems to work fine. No accidents
  4. Patrick Wong
    18,210
    6,517
    1. Regarding the "fan", we are talking about the two radiator fans; not the cabin ventilation fan. I suggest you turn on the AC compressor, open the hood, and make sure that both fans are running and sucking air from the front of the car and blowing it through the radiator.
    2. There is no reason for the AC to stop working at high engine RPM, but it might stop working at freeway speeds if the radiator fans are blowing in the wrong direction.
  5. franken1313
    franken1313 Member
    216
    27
    US
    Yes radiator fan under the hood is turning. Fan Doesn't seem slow. Seems normal & fast. That's exactly when the ac stops working when I get on the highway or when I'm speeding for a while.
  6. Patrick Wong
    18,210
    6,517
    I suggest you determine in what direction are the radiator fans moving air.
  7. franken1313
    franken1313 Member
    216
    27
    US
    Well its never been changed. I bought it new from the delete in 2005
  8. franken1313
    franken1313 Member
    216
    27
    US
  9. Patrick Wong
    18,210
    6,517
    From the grille, towards the engine. Same direction as the air would naturally flow as the car moves forward.
  10. franken1313
    franken1313 Member
    216
    27
    US
  11. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Check for flow in the inverter coolant reservoir. I've heard that if the inverter overheats then it prevents the aircon compressor from running.
  12. ChapmanF
    18,961
    Unlike a conventional car, where "high RPM" can happen for various reasons (high road speed, downshifting, etc.), the CVT-ish nature of a Prius means that engine RPM is pretty much solely determined by the amount of power being demanded (or dissipated, in the case of full-battery deceleration), so "high RPM" in a Prius is pretty much a synonym for near-maximum power situations, and that's where the clue probably lies. If there is any problem with cooling the inverter, near-maximum power moments are likely to be when it is noticeable. At the highest power demands, the car may even be programmed to shed the A/C for more available propulsion; even pretty old cars had that ability. Usually that's only for a moment during acceleration peaks; do you have a situation, like a long uphill, where you need maximum power from the car for a longer period?
    -Chap
  13. franken1313
    franken1313 Member
    216
    27
    US
    Yes where I live it's all hills. Especially the highway. High speeds going up & down hill
  14. Patrick Wong
    18,210
    6,517
    So, have you checked the inverter coolant reservoir for fluid turbulence when the Prius is READY, which would show the inverter coolant pump is working?
  15. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    The Prius AC Compressor operates electrically, from the HV system, completely separate from engine speed. However, as with most modern vehicles, the AC can be "cut off" during high load (full throttle, or nearly so) conditions to provide the most power from the drivetrain.
    It is perfectly possible that this is happening to your car, either due to full throttle, high inverter temperatures or some other load causing the system to de-activate the AC compressor.
