AC drain tube
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by fusion, Jun 13, 2020.
  1. fusion
    fusion Junior Member
    26
    San Francisco
    2019 Prius Prime
    Anyone know where the AC drain tube is located? I can't seem to find it. I know the previous model was on the passenger side. I went under the car and didn't see it. Would it be under the plastic panels?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Run it for a few minutes with the A/C on full blast.......and then look under the car for water dripping. :)
  3. fusion
    26
    San Francisco
    2019 Prius Prime
    I did and I guess it's not humid enough. No water dripping at all. I'm so confused haha
  4. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    According to another thread located here on this forum, see the attached picture...
    Second attach it is the all schematic, with red arrow is your drain hose.
  5. sam spade 2
    7,035
    2,788
    2017 Prius c
    Sorry for bad instructions.
    It will normally actually extract more water when the fan is on LOW.....and it runs out faster too.
    Try looking immediately after coming home from a drive and turning it OFF.
  6. fusion
    26
    San Francisco
    2019 Prius Prime
    I think this is from the previous model I believe which is easy to find. I done the A/C cleaning on the 2014 Prius plug-in which was easy to find. On the Prime, I just can't find it.
  7. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    My second attached picture comes from a 2019 Prius.
    Source is here.
    You should find it if you go under the car in the passenger side.
  8. fusion
    26
    San Francisco
    2019 Prius Prime
    Still can't find it unfortunately.
  9. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    In this case, you shoul go in the passenger place, inside cabin, take off the rug, and you will see a hose going outside the car trough the deck.
    Here, a video from Corolla, but is almost similar.
  10. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    Just curious, Why do you need to find the drain? Knowing almost entire underside, except the exhaust elements, of Prius Prime is covered by plastic, I would think the drain is out of view without removing the cover. Have you removed suspected passenger side cover?
  11. fusion
    26
    San Francisco
    2019 Prius Prime
    I have the stinky AC issue where I need to pump some cleaner in there to hopefully cure the problem.
    Salamander_King likes this.
