AC error codes 21 / 33 / 41
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Metaldrummer13, Jul 3, 2019.
  1. Metaldrummer13
    Metaldrummer13 New Member
    Louisville KY
    Running into all three of these codes trying to get my AC fixed. I was thinking it may just be the freon, but when researching it a bit since it takes a special mixture for the hybrid, I ran into the troubleshooting trick to see about the error codes. Can’t find a definitive solution and diagnosis for these codes, what are they and would this be something I’m better off taking to get fixed instead of on my own?
  2. ChapmanF
    15,441
    21 is just the solar sensor. You will have that code any time you scan for codes if strong light isn't falling on the sensor on the dash.
    I don't have a Gen 2 repair manual at hand right now, but that's where you'll find the other two, and what to do about them.
  3. Patrick Wong
    18,200
    6,471
    33, or DTC B1433 means you have a problem with an open or short with the power source circuit for the air outlet control servo motor. The problem could be the servo motor, or the wiring to that, or the air conditioning amplifier.
    41, or DTC B1441 is a problem with the air mix control servo motor. That motor has a sensor which shows the position of the servo motor and the sensor value does not change as it should when the motor is operated. The suspect components are similar to those listed for 33 above.
    It is not easy to access those servo motors so expect a big $ invoice for labor effort, not to mention the cost of replacement parts.
    Proud Fijian and Raytheeagle like this.
