1. TwoPriusInTenn
    254
    66
    Tennessee
    2008 -: AC works great and blows cool. After a while the coolant line near the compressor appears tofreeze up and no longer blows cool. Refrigerant level looks good. Also just replaced the thermistor. Anything else I should check?
  2. ChapmanF
    18,894
    Which thermistor did you replace?
    Tombukt2 likes this.
  3. TwoPriusInTenn
    254
    66
    Tennessee
    The outdoor ambient temp sensor (thermistor) in front of the radiator.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Does the airflow from the dash vents change when it stops cooling? What you describe sounds like evaporator freeze-up. The system gets too cold and the water vapor that condenses turns to ice.
    There is a temperature sensor that (should) read how cold the evaporator gets, and the ecu should use that to control the compressor to prevent freezing. I would want to use a capable scantool & read that temperature sensor - is it accurate, and what does it show when there's a problem?
    A guess would be that someone did work (like replacing the evaporator) and didn't refit the temperature sensor into the evaporator fins.
